Guest Razz Posted November 9, 2017 Share Posted November 9, 2017 Hi guys, I am new here, so greetings to all! I own a 94 GZ-R that I have converted to R154 manuel. I am wanting to know about 4 piston front brake calipers. Has anyone got the mounting bolt measurements front the 4 piston calipers? And is it true that they are a bolt on replacement for the smaller 2 piston calipers? I appreciate any help Quote Link to comment Share on other sites More sharing options...
SupraLEDrears Posted November 9, 2017 Share Posted November 9, 2017 Hi yes. They are direct replacements, as is the LS 400 ufc20 ones with a tiny amount of filing. You will need to cut off your brakedust covers because the new discs will be bigger. Toyota made a bracket to fit the 2 pot brakes but the bigger ones sits directly on the hub. Quote Link to comment Share on other sites More sharing options...
