SupraLEDrears Posted November 8, 2017 Share Posted November 8, 2017 So over the last two years it has been getting worse. Sometimes it works, sometimes it doesn't. It will also start really slow and stop halfway then after ten minutes it will be working fine. I've replaced the motor with no luck. A lot of people are saying that it could be the stalk connections. Anything else I can try? Thanks Quote Link to comment Share on other sites More sharing options...
mellonman Posted November 8, 2017 Share Posted November 8, 2017 have you tried turning it another click on the intermittent switch Quote Link to comment Share on other sites More sharing options...
evinX Posted November 8, 2017 Share Posted November 8, 2017 Damaged wire. Your going to have to trace it upto the stalk connections. I have a sapre stalk in the garage. Indicator was playing up but wiper side was fine. I can detatch if and send it out if it turns out yours is shot. Check your wiring first though Quote Link to comment Share on other sites More sharing options...
SupraLEDrears Posted November 8, 2017 Author Share Posted November 8, 2017 Damaged wire. Your going to have to trace it upto the stalk connections. I have a sapre stalk in the garage. Indicator was playing up but wiper side was fine. I can detatch if and send it out if it turns out yours is shot. Check your wiring first though That would be ideal, I'll keep you in the loop. Quote Link to comment Share on other sites More sharing options...
SupraLEDrears Posted November 8, 2017 Author Share Posted November 8, 2017 have you tried turning it another click on the intermittent switch Yep continuously but no effect. Quote Link to comment Share on other sites More sharing options...
