Suspension or bushing squeak
Lewmc93
The past week ive had a annoying squeak start to manifest , ive jacked the car up and it appears to be the passenger front where its coming from. As far as I can tell it's only squeaking when traveling up or down , as per the video my phone is sat on the lower arm and I'm pushing up on the suspension,
I made sure all nuts were torque'd and they were all okay, I sprayed a bit of lube on all the bushings and still persists , I can't seem to locate it by ear but I'm assuming it's either suspension , Or bushings ,
I have searched by nothing seems to have the same noise or problem with only up and down travel , I have attached 2 video links so you can hear the sound and also a quick look to see if I missed anything and also for any other suggestions!
Cheers guys
https://www.dropbox.com/s/5y5uuxqq20lm935/2017-11-08%2014.35.51.mp4?dl=0
https://www.dropbox.com/s/mlvaqti997v0y38/2017-11-08%2014.39.38.mp4?dl=0
Remove the drop link and see if it goes
If so could be drop link or anti roll bar
Had a similar thing and turned out to be drop link
Well good news and bad ,
It's not the arb or droplinks squeaking ,
Bad news is it's still squeaky and I've also managed to sheer the arb mounting bolt in the thread :'( so now have to try get it out and find a new one
Edit :
Also removed lower bolt on strut that joins to the lca, the movement without the strut attached is quiet, looks like it could be the coilovers, but is that likely both to go at the same time ?
Edited by Lewmc93 (see edit history)
