billski Posted November 8, 2017 Share Posted November 8, 2017 So, I first heard an intermittent rotational clunking noise at slow speed in traffic about 30 miles ago. When I arrived home it was much more consistent and louder. Tried to start the car next day and it won't turn over. Plenty of battery power and no clicking. (Sorry - manual tt) Link to comment Share on other sites More sharing options...
Al Massey Posted November 8, 2017 Share Posted November 8, 2017 Crank pulley fallen off/in bits/two halves have separated? Link to comment Share on other sites More sharing options...
Dnk Posted November 8, 2017 Share Posted November 8, 2017 Are you sure the battery has enough life in it ? have you put a meter on it Broken cp shouldn't affect it cranking over Link to comment Share on other sites More sharing options...
billski Posted November 8, 2017 Author Share Posted November 8, 2017 Crank pulley is intact Al Link to comment Share on other sites More sharing options...
billski Posted November 8, 2017 Author Share Posted November 8, 2017 Battery is kk - tried a booster anyway no joy. Link to comment Share on other sites More sharing options...
Guest Rsb Posted November 8, 2017 Share Posted November 8, 2017 Could it be starter motor if battery ok, or fuel pump? Link to comment Share on other sites More sharing options...
Scooter Posted November 8, 2017 Share Posted November 8, 2017 It could be yes Was it clunking only when moving or at idle too. Have you tried turning it manually, 22mm socket on the crank pulley, try as is and then without the aux belt if you can't with. Link to comment Share on other sites More sharing options...
billski Posted November 8, 2017 Author Share Posted November 8, 2017 Only when moving Scooter that's what's a bit weird cos I don't think it's coincidence. Yeh I'll try the the crank pulley later no time atm, thx Link to comment Share on other sites More sharing options...
Al Massey Posted November 8, 2017 Share Posted November 8, 2017 Broken cp shouldn't affect it cranking over I was thinking if it had broken during the drive, none of the auxiliaries would have worked which would cause other problems. - - - Updated - - - When you say wont turn over, is it cranking or is there nothing? Link to comment Share on other sites More sharing options...
billski Posted November 8, 2017 Author Share Posted November 8, 2017 There's nothing At all Al - or (noting ur locality) should I say "nowt?" Link to comment Share on other sites More sharing options...
billski Posted November 8, 2017 Author Share Posted November 8, 2017 I'll have a look at turning the crank pulley later - and the other pulleys if needs be. Link to comment Share on other sites More sharing options...
Scooter Posted November 8, 2017 Share Posted November 8, 2017 Dash lights all good though? Link to comment Share on other sites More sharing options...
Al Massey Posted November 8, 2017 Share Posted November 8, 2017 There's nothing At all Al - or (noting ur locality) should I say "nowt?" Nowt wrong wi tha Link to comment Share on other sites More sharing options...
Scooter Posted November 8, 2017 Share Posted November 8, 2017 Check the alternator pulley if you do remove the belt........some similarities to Jive's issue from way back! http://www.mkivsupra.net/vbb/showthread.php?105408-Help-1-Dead-Supe-(not-crashed)&highlight=straw Link to comment Share on other sites More sharing options...
billski Posted November 8, 2017 Author Share Posted November 8, 2017 Well - I just turned the crank pulley by hand. Tried again started np. Something must have been jammed!! Too scared to drive it atm lol so don't know about the clunking hopefully it's just the parking brakes. Link to comment Share on other sites More sharing options...
Scooter Posted November 8, 2017 Share Posted November 8, 2017 Could be the starter motor as these can go intermittent before completely failing. Link to comment Share on other sites More sharing options...
stevie_b Posted November 9, 2017 Share Posted November 9, 2017 Could be the starter motor as these can go intermittent before completely failing. Agreed - thats what happened to mine. I'd try to start it and absolutely nothing would happen. No clicking, no cranking, no anything. I'd leave it a few seconds and try again, and it would start with no problems. I had the contacts on the starter motor refurbed, and that fixed the problem. Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 9, 2017 Share Posted November 9, 2017 First check if the starter motor is loose. If so tighten it, if not remove and inspect. Whilst down there see if the flywheel / flex plate is loose. Link to comment Share on other sites More sharing options...
gdog1989 Posted November 10, 2017 Share Posted November 10, 2017 Mine done that before it was the starter that had packed up Link to comment Share on other sites More sharing options...
