Rear frame, diff and suspension torque specs
rider
I have compiled a comprehensive list of torque specs for my rear end underside refurb rebuild which may be useful for others:
Torque setting
Frame to body
Rear frame rear cushions 43 lb/ft (58NM)
Rear frame front cushions 129 lb/ft
Prop and differential
Prop to diff bolts 58 lb/ft
Drive shaft to differential 61 lb/ft
Differential mount bolts front 108 lb/ft
Differential mount bolts rear 105 lb/ft
Sway bar
Stabilizer bar drop link (both) 54 lb/ft
Stabilizer bar bracket 13 lb/ft
Suspension arms
Upper arm to frame 121 lb/ft
Upper arm ball joint nut 80 lb/ft
Lower #2 arm to frame 136 lb/ft
Lower #2 arm ball joint nut 121 lb/ft
Lower #2 arm to shock 101 lb/ft
Lower #1 arm to frame 136 lb/ft
Lower #1 arm ball joint nut 43 lb/ft
Strut rod to frame 136 lb/ft
Strut rod to hub 136 lb/ft
Hub
Shaft Lock nut 213 lb/ft
Others
Brake calliper to hub 77 lb/ft
Exhaust cat #2 to pipe bolts 43 lb/ft
Hand brake cable to hub plate bolts 69 lb/ft
Handbrake shoe guide plate bolt 13 lb/ft
Handbrake cable clamp to frame bolts 14 lb/ft
I'd always advise people to check torque settings for themselves but these are what I'm going with.
  • Like 1
