Clutch replacement
Weka
My friend's clutch on his 6sp MKIV is on the way out and he wants to know what other choices are there apart from the HKS twin/triple plates which a tuner is trying to get him to buy.
I think they would not be suitable/necessary as the car is about 400hp and his driving is mostly in town.
He wants something not too expensive as he will sell the car later in the year.
Any suggestions?
Thanks
Any suggestions?
Thanks
Nothing whatsoever wrong with the stock clutch at that level
There are loads of "better" options for the money.
Get your mate to talk to a proper tuner like Leon, CW or TDi....
RPS
Tilton
Blitz
TRD
Leon's new lightweight flywheel + kevlar clutch has gone down well with Ashley and Terry S
Any suggestions?
Thanks
Yes, see below:
Available now: Uprated MKIV TT clutches.
I have instigated a few new performance parts for the MKIV
Supra TT's. I will announce when things become available,
but one which is available NOW is an uprated clutch assembly.
I use the stock, brand new driven plate, as it is correctly
balanced, doesn't judder and will hold all but mega torque
highly modded engines or cars used for drag racing.
I modify a stock brand new cover to give more clamping force.
The reason I tooled up to do these is some of the aftermarket
US clutches I have fitted SEEM to be built from used cover
assemblies with reground friction surfaces, and a stronger
spring. I have had hellish trouble getting these to fully
release, because due to this seemingly thinner cast iron
friction face, the geometry of the clutch goes to pot, and
being a pull type clutch (the hydraulics pull the bearing
away from the engine, rather than the more normal push type)
it is a lot harder to effect a cure.
Anyway, for a short period I will do the uprated units for
375 pounds. You get a brand new driven plate, a brand new
modded cover, and a brand new release bearing. I would
rather fit myself so any complaints are down to me, I see
too many clutches juddering due to someone without the right
gear allowing the gearbox input shaft to bend the driven plate
as the boxes' weight is allowed to swing on the plate centre,
or clutches fitted to patently buggered flywheels. Toyota use
a dual mass flywheel (the flywheel is in 2 parts, an inner and
outer assembly, damped in the middle) which is now showing signs
of wear causing a lot of rattle when idling or on very light
throttle openings. For God knows what reason they are charging
about 270 quid for a new one, they look more like they should be
over 500 to me, but don't say anything :-) So if the flywheels
old enough or abused enough to be scored it's best replaced.
If pressed I will sell the clutch kit, which includes a new release
bearing for a 3rd party to fit.
Fitting by myself will cost 175. Both prices do not incur any VAT,
I have a separate company for road car stuff, and it's not VAT registered.
Reply privately if interested please. [email protected]
RPS
Tilton
Blitz
TRD
Would you know Leon's price?
Originally posted by eyefi
the full set (light flywheel, kevlar driven plate and pressure plate) is about £900. i dont know the prices for the individual items for comparison tho. this isnt a setup id put in the car to sell tho.
Thanks
May be abit too much for him as he is looking to sell the car later in the year.
