Brake Line -- connecting your remote reservoir to your master cylinder
Jellybean
Hi
Motorbike
Have some Tygon line on the rear (connecting the remote reservoir to the master cylinder) but the engine heat is causing it to perish
Will Gates Racing Fuel line suffice?
Key Features and Benefits:
• Cover resists heat, oil, ozone and weathering with spiral textile reinforment
• Tube has been upgraded to meet changes in fuel characteristics and resists heat and oil
• Working pressure up to 1 MPa (10 kg/cm²)
• Temperature range from -35°C to +125°C
• Meets requirements of SAE J30R7 and DIN 73379 (except for tolerances)
thanks
Thanks Chris , I actually found the OE one I had on prior :)
Was interested in the answer all the same , most lines I could find only where AN type braided
Just on a side note to get your insight , I fitted a new Oberon Clutch Slave the weekend, it has a rock hard Clutch lever after I bled it
Considering these are very single little units in design and to fit , I presume it is faulty
its a 2002 748s
Repro steps
  • Installed to the Bike and Bleed as per instructions, the bike has a rock hard Clutch lever (the Pre 2000 Push Rod Spacer was NOT used)
  • Unbolted the Oberon unit from the bike , to test if the piston in the Slave would move , still rock hard Clutch lever , no slave piston movement
  • The OEM Slave was re-installed and Bled , no issues
Hi Chris ,
The piston was at the very end of the bore , I tried to move the piston but to no avail , gave it a little more pressure and it freed up with a rush of air ; it appears it was 'stuck' , may from storage and just need to be dislodged , when I try to push it now it will 'bounce' back towards the end of the bore
Hopefully should be ok now
