boostman Posted October 31, 2017 Share Posted October 31, 2017 Went to lift the rear with a trolly jack and some wood between the cup and diff. When I started lifting it was making a rather disconcerting creaking, like the sound of serveraly rusty sheet metal bending and breaking.... I only lifted maybe 3 inches then let it back down again. Anyone else jack from the diff with any issues? Thanks Link to comment Share on other sites More sharing options...
Rajinder Posted October 31, 2017 Share Posted October 31, 2017 Always jacked from the diff with no issues. Link to comment Share on other sites More sharing options...
Mike2JZ Posted October 31, 2017 Share Posted October 31, 2017 I always jack off the diff or front subframe. Maybe your suspension was creaking? Or your diff mounts are severely worn Link to comment Share on other sites More sharing options...
stevie_b Posted October 31, 2017 Share Posted October 31, 2017 Same here, always done it with no problems. Link to comment Share on other sites More sharing options...
and1c Posted October 31, 2017 Share Posted October 31, 2017 Diffs a solid point to jack from. was probably the wood crunching Link to comment Share on other sites More sharing options...
squiffy Posted October 31, 2017 Share Posted October 31, 2017 Just make sure you are on the underside of the diff and not under the backplate Link to comment Share on other sites More sharing options...
boostman Posted October 31, 2017 Author Share Posted October 31, 2017 It was a very odd noise, but if there no damage to be done I'll stop listening and jack away!Just make sure you are on the underside of the diff and not under the backplate /QUOTE]What do you mean back plate? I had the jack under the smooth bit in the center of the diff. Link to comment Share on other sites More sharing options...
and1c Posted October 31, 2017 Share Posted October 31, 2017 It was a very odd noise, but if there no damage to be done I'll stop listening and jack away!What do you mean back plate? I had the jack under the smooth bit in the center of the diff. . Yeah, just make sure its centered under the diff casing. I have jacked from here loads of times and you have nothing to worry about as long as you are under the diff casing. Link to comment Share on other sites More sharing options...
Wez Posted November 1, 2017 Share Posted November 1, 2017 As above, never had an issue jacking the rear from the diff, easiest place to access Link to comment Share on other sites More sharing options...
boostman Posted November 1, 2017 Author Share Posted November 1, 2017 Thanks for the reassurance, I'll give it another go this evening or tomorrow [emoji106] Link to comment Share on other sites More sharing options...
Scooter Posted November 1, 2017 Share Posted November 1, 2017 Tyres can also make a funny noise as you lift and drop as they sort of scuff inwards on the way up and outwards when you drop it down. When it's up, take a close look at the rear diff bushes as you see any perishing cracks at their worst. Does you car have both bushes? Link to comment Share on other sites More sharing options...
rider Posted November 1, 2017 Share Posted November 1, 2017 The diff is a solid heavy lump, I know - I'm getting mine ready for paint at the moment. So nothing in the diff or the frame its attached to is going to creak or groan on lifting a car. Needs checking out though till you are sure everything is there, in the correct place and secure. Link to comment Share on other sites More sharing options...
boostman Posted November 1, 2017 Author Share Posted November 1, 2017 Tyres can also make a funny noise as you lift and drop as they sort of scuff inwards on the way up and outwards when you drop it down. When it's up, take a close look at the rear diff bushes as you see any perishing cracks at their worst. Does you car have both bushes?No it just has the single bush which is in good condition, I'll check the rest when it's on stands. There wasn't any movement from the diff, each pump of the jack moved the car not the diff. I think I was just being a fanny when it was creaking [emoji14] Link to comment Share on other sites More sharing options...
boostman Posted November 1, 2017 Author Share Posted November 1, 2017 The diff is a solid heavy lump, I know - I'm getting mine ready for paint at the moment. So nothing in the diff or the frame its attached to is going to creak or groan on lifting a car. Needs checking out though till you are sure everything is there, in the correct place and secure.Yes I'm pretty sure I had the wood/ jack under the flat bit in the center, not under the rear cover or the fins towards the front Link to comment Share on other sites More sharing options...
Scooter Posted November 1, 2017 Share Posted November 1, 2017 No it just has the single bush which is in good condition, I'll check the rest when it's on stands. There wasn't any movement from the diff, each pump of the jack moved the car not the diff. I think I was just being a fanny when it was creaking [emoji14] Always better to be safe than sorry when diy'ing! weren't you going NA-T? might be worth doing the second bush at some point. Link to comment Share on other sites More sharing options...
boostman Posted November 1, 2017 Author Share Posted November 1, 2017 Always better to be safe than sorry when diy'ing! weren't you going NA-T? might be worth doing the second bush at some point.No staying NA for now [emoji14] Link to comment Share on other sites More sharing options...
machman Posted November 1, 2017 Share Posted November 1, 2017 Yes it's it's the recommended jack point according to the manual, just remove any extra load from the boot. Link to comment Share on other sites More sharing options...
