Jacking from the diff
boostman
Went to lift the rear with a trolly jack and some wood between the cup and diff. When I started lifting it was making a rather disconcerting creaking, like the sound of serveraly rusty sheet metal bending and breaking....
I only lifted maybe 3 inches then let it back down again.
Anyone else jack from the diff with any issues?
Thanks
It was a very odd noise, but if there no damage to be done I'll stop listening and jack away!
Just make sure you are on the underside of the diff and not under the backplate
/QUOTE]What do you mean back plate? I had the jack under the smooth bit in the center of the diff.
It was a very odd noise, but if there no damage to be done I'll stop listening and jack away!What do you mean back plate? I had the jack under the smooth bit in the center of the diff.
Yeah, just make sure its centered under the diff casing. I have jacked from here loads of times and you have nothing to worry about as long as you are under the diff casing.
Tyres can also make a funny noise as you lift and drop as they sort of scuff inwards on the way up and outwards when you drop it down.
When it's up, take a close look at the rear diff bushes as you see any perishing cracks at their worst. Does you car have both bushes?
The diff is a solid heavy lump, I know - I'm getting mine ready for paint at the moment. So nothing in the diff or the frame its attached to is going to creak or groan on lifting a car. Needs checking out though till you are sure everything is there, in the correct place and secure.
No it just has the single bush which is in good condition, I'll check the rest when it's on stands. There wasn't any movement from the diff, each pump of the jack moved the car not the diff.
I think I was just being a fanny when it was creaking [emoji14]
Yes I'm pretty sure I had the wood/ jack under the flat bit in the center, not under the rear cover or the fins towards the front
Always better to be safe than sorry when diy'ing! weren't you going NA-T? might be worth doing the second bush at some point.
