mark newman Posted October 29, 2017 Share Posted October 29, 2017 Whats the best injectors to use on a 1500 bhp set up, and ok to use with race fuel , would it be ID 2000 before I order them . Any help would be good . Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted October 29, 2017 Share Posted October 29, 2017 I think with that power people would be inclined to run 12 injectors but I could be completely wrong Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 30, 2017 Share Posted October 30, 2017 Such massive injectors probably won't allow a very good stable idle and reasonable economy *IF* the engine is for any real road usage. Twin staged injectors would be far better for that, but if it's race only and economy and manners are secondary, they should do the job. As a 1500 BHP 3 or 3.4 litre engine is definitely a race engine with life measured in hours I guess single injector per pot will make things a lot simpler! Quote Link to comment Share on other sites More sharing options...
mark newman Posted October 30, 2017 Author Share Posted October 30, 2017 Yes race engine . Now and again on the road. But mainly drag . Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 30, 2017 Share Posted October 30, 2017 Keep it simple and go for big injectors, sod the idle and emissions The only reason Cosworth went with dual injectors on the Sierra Cosworth Group A engines was lack of ECU technology to control massive injectors (it wasn't long after the big players like Volvo were using V8 mechanical injection metering heads to deploy enough fuel, so quite crude still) and the need to finish a touring race without a petrol bowser being towed behind Quote Link to comment Share on other sites More sharing options...
mark newman Posted October 31, 2017 Author Share Posted October 31, 2017 Yes I like simple . And will not be going with I'd 2000s as there is to much bad press. I think siemans 2200 will be the way to go . Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted October 31, 2017 Share Posted October 31, 2017 Have you looked at ASNU injectors Mark? Quote Link to comment Share on other sites More sharing options...
