ben_harmer32 Posted October 26, 2017 Share Posted October 26, 2017 Are N.A. and TT fuel rails the same? Link to comment Share on other sites More sharing options...
Mike2JZ Posted October 26, 2017 Share Posted October 26, 2017 Nope. NA fuel rail supports top feed injectors TT fuel injectors support side feed injectors Link to comment Share on other sites More sharing options...
ben_harmer32 Posted October 26, 2017 Author Share Posted October 26, 2017 Nope. NA fuel rail supports top feed injectors TT fuel injectors support side feed injectors are the rails interchangeable? Link to comment Share on other sites More sharing options...
Mike2JZ Posted October 26, 2017 Share Posted October 26, 2017 are the rails interchangeable? The mounting positions for the rails are different between GE & GTE. With a bit of fabrication work you could modify the fuel rail from a GE to fit a GTE manifold or vice versa. But it's not a straight forward bolt on and go Link to comment Share on other sites More sharing options...
Al Massey Posted October 26, 2017 Share Posted October 26, 2017 What fuel rail are you after? Link to comment Share on other sites More sharing options...
mattdavies Posted October 26, 2017 Share Posted October 26, 2017 What are you trying to achieve ? Link to comment Share on other sites More sharing options...
sidewaysdan Posted October 26, 2017 Share Posted October 26, 2017 Why do you need th change the rail Link to comment Share on other sites More sharing options...
