Facelift and pre-facelift suspension arms
berg
Is there any difference in the size of the bushes on the facelift vs pre-facelift front suspension arms?
Im in the process of buying a full poly bush kit from strongflex but they list it for all supras 93-02 and no mention of difference up front
The only options other than the usual arb and rack bushes are below
Rear trailing arm front bush 34mm
Rear trailing arm front bush 46mm
And
Rear track control arm outer bush 39mm
Rear track control arm outer bush 40,5mm
Anyone know which of the above is the correct size?
And whether there are differences on the size of the fronts on the facelifts?
Hi mate
I'm positive there are. I am sure the pre-facelift ones are stronger but it could be the other way round [emoji23] One of the variations is better definitely.
Here we go...
http://www.mkivsupra.net/vbb/showthread.php?t=321314
I might be parting way with my full brand new OEM suspension setup if interested. Only upper arms missing as they shouldn't wear.
Have you got original setup on car then?
Greg
Hi Greg
Cheers for the link
if its just strength thats different then thats fine as the poly bushes will fit both size wise
Guess ill just need to work out the size i need for the rear trailing arms and track control arms as looking on that thread you linked it seems thats the size difference on the facelift vs pre-facelift
My setup is stock at the moment, front lower arms were changed in 2013 according to paperwork so ball joints should be good, ball joints on all the others seem good thats why im gonna go for the poly bushes instead ofg spending thousands on stock parts
Anyone able to help on which size bushes i need for the 2 arms in question below on the diagram?
From the thread posted by Greg above it seems the larger one for the trailing arm bush but not sure 100%
Dont want to end up buying twice lol
211627 on diagram (34mm)
OR
211694 (46mm)
211631 (39mm)
211632 (40.5mm)
