Singapore Supra Posted September 28, 2005 Share Posted September 28, 2005 hi guys, i noticed a loud rattling noise from the underside of my car when idiling. but it goes off when i depress the clutch. i cant go into 2nd gear at high revs as well.(could be the synchros?) i have a triple plate clutch, i think its OS Giken, cos the pressure plate is gold in colour. what could be the problem? thanks.... Link to comment Share on other sites More sharing options...
SimonB Posted September 28, 2005 Share Posted September 28, 2005 The rattle will be because you have a lightweight flywheel, which is not damped like the standard one. That causes the gearbox to rattle, especially when hot. There's not much you can do apart from put up with it. Link to comment Share on other sites More sharing options...
Singapore Supra Posted September 28, 2005 Author Share Posted September 28, 2005 The rattle will be because you have a lightweight flywheel, which is not damped like the standard one. That causes the gearbox to rattle, especially when hot. There's not much you can do apart from put up with it. thanks fo yr info. but it wasnt rattling at all before, until my 2nd gear syncro is gone. Link to comment Share on other sites More sharing options...
