Engine Cuts off
Guest mmbasstram
Guest mmbasstram
so currently issue i am having is while the engine is running after a few minutes of driving it will shut off on me. i will start it back up sometimes it will run sometimes it will just cut right back off. had a friend tell me to disconnect the IAC and see if it ran and all it did was climb up to 4000 rpm and shut off. fuel pump, fuel pump eco, fuel filter, and EFI relay were replaced about three years ago. its a '95 NA supra. please any help would be appreciated so i can drive her all i want.
I had the exact same problem with my 1jz soarer, I don't know if the same applies to the supra?
There was a fuel pump ecu that switches the pump between 2 speeds.
You could bypass it by putting a link in the diagnostic port and make it run full speed all the time.
That might be helpful or completely irrelevant [emoji23]
