My electric fans turning off a little early
a98pmalcolm
Hey gang,
Not a straight forward one but I have an SRD rad fan kit and I wired them into the AC fan loom so they kick in around 96 degrees (so they come one when the little OEM AC fan is meant to come on)
Been running this set up for a few years but I think they turn off a little early currently (around 94 degrees)
I'm pretty sure they used to turn off around 91 degrees.
Is there anything worth checking or can the AC fan switch be turned on earlier via Syvecs?
I could just be paranoid but I'm pretty sure something has randomly changed
Im pretty sure the stock switch does usually turn them off around 91 or 92
Its a temp switch in the bottom of the rad
Hey gang,
Thanks Lee, yes I thought around 91 too. I will keep and eye on it. If it does seem to turn off too early it might be worth me changing the sensor at the bottom of the rad maybe..
