a98pmalcolm Posted October 19, 2017 Share Posted October 19, 2017 Hey gang, Not a straight forward one but I have an SRD rad fan kit and I wired them into the AC fan loom so they kick in around 96 degrees (so they come one when the little OEM AC fan is meant to come on) Been running this set up for a few years but I think they turn off a little early currently (around 94 degrees) I'm pretty sure they used to turn off around 91 degrees. Is there anything worth checking or can the AC fan switch be turned on earlier via Syvecs? I could just be paranoid but I'm pretty sure something has randomly changed Quote Link to comment Share on other sites More sharing options...
Lee P Posted October 19, 2017 Share Posted October 19, 2017 Im pretty sure the stock switch does usually turn them off around 91 or 92 Its a temp switch in the bottom of the rad Hey gang, Not a straight forward one but I have an SRD rad fan kit and I wired them into the AC fan loom so they kick in around 96 degrees (so they come one when the little OEM AC fan is meant to come on) Been running this set up for a few years but I think they turn off a little early currently (around 94 degrees) I'm pretty sure they used to turn off around 91 degrees. Is there anything worth checking or can the AC fan switch be turned on earlier via Syvecs? I could just be paranoid but I'm pretty sure something has randomly changed Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted October 19, 2017 Author Share Posted October 19, 2017 Im pretty sure the stock switch does usually turn them off around 91 or 92 Its a temp switch in the bottom of the rad Thanks Lee, yes I thought around 91 too. I will keep and eye on it. If it does seem to turn off too early it might be worth me changing the sensor at the bottom of the rad maybe.. Quote Link to comment Share on other sites More sharing options...
