r154 into mkiv driveshaft queery
jonny mac
hi guys
recently I have done an r154 conversion into a soarer using a mk3 supra front propshaft and soarer front propshaft carrier bearing
i'll be fitting an r154 into my mkiv shortly and was wondering if the same goes as I believe the supra and soarer are the same floor pan?
so I'd be safe enough using a mk3 prop with mkiv supra carrier bearing and housing ?
just before I go out and spend money on a mk3 prop and it turns out to be wrong for my car
