Guest Sbn1979 Posted October 15, 2017 Share Posted October 15, 2017 I have a 1993 auto. Usually starts first time with some cranking, after shutting off, even 10 secs after, won’t restart without brake cleaner. Ect sensor checks out with a sensible resistance @20c Swapped out cam sensor I loose injector pulse on second crank, again when it catches with brake cleaner all is well Ideas ? Thanks Quote Link to comment Share on other sites More sharing options...
Scooter Posted October 15, 2017 Share Posted October 15, 2017 NA or TT? plugs last changed when? Quote Link to comment Share on other sites More sharing options...
Guest Sbn1979 Posted October 15, 2017 Share Posted October 15, 2017 NA or TT? plugs last changed when? TT and new plugs Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 16, 2017 Share Posted October 16, 2017 Possibly a failing IGF signal, or a crank sensor / sensor connection. Needs a scope on it if no sensible fault codes stored. Quote Link to comment Share on other sites More sharing options...
Guest Sbn1979 Posted October 17, 2017 Share Posted October 17, 2017 Cranks sensor scopes fine but I have found out it has a blitz ecu in it? Quote Link to comment Share on other sites More sharing options...
