moonstone Posted October 4, 2017 Share Posted October 4, 2017 Like the title says. Love the look of both. Did you see any benefits over a normal 3 inch pod filter or drop in filter? I think either of those with a proper heat shield would definitely add some hp. Here are some pics: TBdev. 2jzmotorsports Verzonden vanaf mijn iPhone met Tapatalk Link to comment Share on other sites More sharing options...
Chris Bailey Posted October 4, 2017 Share Posted October 4, 2017 If I had a TT I'd just stick with the OEM air box with the cold air feed, and add something like a K&N panel filter. For performance purposes I'd have thought that will work best. Link to comment Share on other sites More sharing options...
Frank Bullitt Posted October 4, 2017 Share Posted October 4, 2017 Hot air from the engine bay won't give you more power, stick with the stock airbox and an aftermarket panel filter. Link to comment Share on other sites More sharing options...
moonstone Posted October 4, 2017 Author Share Posted October 4, 2017 Agreed with both of you, thats why I wrote about a proper heat shield. I think it can pull a lot of extra air compared to a panel filter or the 3 inch pod filter. But I’m wondering if anyone on the forum tried it and has some data to share Verzonden vanaf mijn iPhone met Tapatalk Link to comment Share on other sites More sharing options...
Hitbox Junkie Posted October 4, 2017 Share Posted October 4, 2017 for BPU/stock twins not sure your see much more benefit best bet is to use the stock set up with a aftermarket air filter. Link to comment Share on other sites More sharing options...
Chris Bailey Posted October 4, 2017 Share Posted October 4, 2017 Agreed with both of you, thats why I wrote about a proper heat shield. I think it can pull a lot of extra air compared to a panel filter or the 3 inch pod filter. But I’m wondering if anyone on the forum tried it and has some data to share Verzonden vanaf mijn iPhone met Tapatalk What do you mean by a proper heat shield? Why do you think a heat shield would help? You're still going to draw in hot air to the air filters. Unless they are enclosed in a box with a cold air feed? I'm struggling to understand what you are trying to get at? Link to comment Share on other sites More sharing options...
moonstone Posted October 4, 2017 Author Share Posted October 4, 2017 Well you have two options: 1) sealed air box like you are suggesting 2) heat shield till the bonnet, so no hot air will be drawn to the filters. Similar to the max air box, which is a proven formula for years. With both you can use the oem snorkel to provide cold air. Sorry I can’t make it more specific. English is not my first language [emoji6] Verzonden vanaf mijn iPhone met Tapatalk Link to comment Share on other sites More sharing options...
moonstone Posted October 4, 2017 Author Share Posted October 4, 2017 This is the heat shield/box I’m thinking of, but with dual or 4 inch filter. Verzonden vanaf mijn iPhone met Tapatalk Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 4, 2017 Share Posted October 4, 2017 A pair of el cheapo vac gauges or home made manometers will tell you immediately if the intakes are restrictive. Altering the intake lengths to the 2 turbos is probably NOT a good idea. I very much doubt any post seventies engine has a restrictive intake, makers were chasing MPG and restrictions in the intake kill them. Link to comment Share on other sites More sharing options...
Sheefa Posted October 4, 2017 Share Posted October 4, 2017 I'm running single but have just collected by new air intake custom pipe, courtesy of TB Developments, and I'll be running a filter out of engine bay by headlight slightly under car (see pic 3 hole) which will be enclosed in a custom airbox. Link to comment Share on other sites More sharing options...
Burna Posted October 5, 2017 Share Posted October 5, 2017 I'm running single but have just collected by new air intake custom pipe, courtesy of TB Developments, and I'll be running a filter out of engine bay by headlight slightly under car (see pic 3 hole) which will be enclosed in a custom airbox. https://uploads.tapatalk-cdn.com/20171004/219a2437fa597bbd6180ec84634c350f.jpghttps://uploads.tapatalk-cdn.com/20171004/4481f657f4420cfab478d2213f2a1594.jpghttps://uploads.tapatalk-cdn.com/20171004/5126d842844dadbd44c741b241076e38.jpg /QUOTE] Sexy bit of work there by Tim! Link to comment Share on other sites More sharing options...
Al Massey Posted October 5, 2017 Share Posted October 5, 2017 This is the heat shield/box I’m thinking of, but with dual or 4 inch filter. https://uploads.tapatalk-cdn.com/20171004/111887f190a194fb836364eda9dd261f.jpg Here is my heat shield that I made up and still fettling with. Forms a perfect seal against the bonnet too. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 5, 2017 Share Posted October 5, 2017 The more outside/cold air you can get into the intake the better, the colder the air the denser it is, which equals more fuel, however the size of the intake was designed to accommodate more than the maximum amount of air required by the engine in its normal configuration, so i doubt that adding two intakes will make a difference. Link to comment Share on other sites More sharing options...
Hitbox Junkie Posted October 5, 2017 Share Posted October 5, 2017 Here is my heat shield that I made up and still fettling with. Forms a perfect seal against the bonnet too. [ATTACH]222701[/ATTACH] [ATTACH]222702[/ATTACH] What material are you using? Looks great Link to comment Share on other sites More sharing options...
Steffen A Posted October 7, 2017 Share Posted October 7, 2017 I've made a custom "airbox" for my A80. It guards for all of the hot air from the engine, and also meets with the danish law regarding open air filters (open filters are not allowed on the street...). This way i keep the open air filter sound and i love the looks of the green HKS mushroom filter. Still kind of prototype, have thought of making it in a better way with other materials. Made of aluminium. Link to comment Share on other sites More sharing options...
Sheefa Posted October 7, 2017 Share Posted October 7, 2017 I've made a custom "airbox" for my A80. It guards for all of the hot air from the engine, and also meets with the danish law regarding open air filters (open filters are not allowed on the street...). This way i keep the open air filter sound and i love the looks of the green HKS mushroom filter. Still kind of prototype, have thought of making it in a better way with other materials. Made of aluminium.Looks good mate although mushroom filters are AWFUL for cooling. Much better with stock panel or a proper cone like K&N. Link to comment Share on other sites More sharing options...
Al Massey Posted October 7, 2017 Share Posted October 7, 2017 What material are you using? Looks great Aluminium with reflective heat wraps. And the top have soft leather strips to seal it up on the bonnet. Link to comment Share on other sites More sharing options...
james_cbr Posted October 7, 2017 Share Posted October 7, 2017 I love the duel filter look wouldn't mined the pipes for mine Link to comment Share on other sites More sharing options...
