blythmrk Posted September 27, 2017 Share Posted September 27, 2017 Complete pair of Rear Hubs with Strongflex yellow poly bushes fitted. These have been removed from a refurbished rear sub frame that I bought off Keron the hubs are in very good order plus the wheel bearings (very smooth and well greased) too were replaced when the subframe was refurbished these have not covered many miles. They are complete with handbrake shoes and fittings (again they look to have been renewed recently apart from the shoes) the hubs have had a good coat of black paint. One of the heat shields has been trimmed to allow the use of UK rear discs (this is normal practice as the UK rear heat shields are £300 per side I know I have bought some!) the other side has been removed apart from the backing plate (these are fine to use as is) please see pics. The only small issue is that the cables are snapped on both hubs (this is a common problem too) but I have a new set of Blue Print (Exactly like oem ones and they come with the brackets) that I can let go for an extra £50 if required. The only thing not included is the ABS Sensors. Please excuse the yellow labels these are marked up O/s & N/S so I cannot fit them on the wrong side:D I have no use for these as I wanted to keep my UK cars with the correct UK heat shields. £140ono or £190ono with the new cables plus £20 delivery in the UK or collection welcome from near Sheffield. [ATTACH=CONFIG]222589[/ATTACH] [ATTACH=CONFIG]222590[/ATTACH] [ATTACH=CONFIG]222591[/ATTACH] [ATTACH=CONFIG]222592[/ATTACH] [ATTACH=CONFIG]222593[/ATTACH] [ATTACH=CONFIG]222594[/ATTACH] Link to comment Share on other sites More sharing options...
markssupra Posted September 28, 2017 Share Posted September 28, 2017 pm'd Link to comment Share on other sites More sharing options...
blythmrk Posted September 28, 2017 Author Share Posted September 28, 2017 Sold with new cables. Link to comment Share on other sites More sharing options...
