mkiv n/a manual pinout help / not on wilbo666
jonny mac
now, http://wilbo666.pbworks.com/w/page/41678224/2JZ-GE%20JZA80%20Supra%20Engine%20Wiring
wilbo's diagram and pinout info are all about mkiv n/a automatic cars
I'm looking for the exact same info but for a mkiv manual n/a prefacelift
I need to get a pinout for the body connectors inside the car on the ecu loom and also the fusebox connectors in the engine bay
I'm planning to open up my manual loom on the floor, cut out all the actual ecu wiring, do the same to the aristo loom and then make a hybrid of the two so I have a supra loom using an aristo ecu and engine connector set
any help would be greatly appreciated, I'm probably not searching for the right things :D
thank you, some fantastic info there:
http://www.mkivsupra.net/vbb/showthread.php?263818-1JZ-Project-Tips-and-Advice-Most-Welcome&p=3321971&viewfull=1#post3321971
on this post, is that the pinout of the supra bodyplug down by the ecu? I'm keen to find an exact pinout of the supra bodyplugs that connect to the dash loom beside the ecu
unless they are the same plugs just missing the auto stuff between manual/auto cars?
the wilbo jza80 ecu bodyplugs are a great reference just unsure how similar they are to a manual loom
Edited by jonny mac (see edit history)
They are the same dude. Everything highlighted in blue on Wilbro666 is an automatic only wire and will be missing from a manual loom. It's as easy as that. The only interior plugs you will need to care about is the Orange & grey one. The small white one is only found on auto looms and dosen't control anything when using a manual.
