jonny mac Posted September 27, 2017 Share Posted September 27, 2017 now, http://wilbo666.pbworks.com/w/page/41678224/2JZ-GE%20JZA80%20Supra%20Engine%20Wiring wilbo's diagram and pinout info are all about mkiv n/a automatic cars I'm looking for the exact same info but for a mkiv manual n/a prefacelift I need to get a pinout for the body connectors inside the car on the ecu loom and also the fusebox connectors in the engine bay I'm planning to open up my manual loom on the floor, cut out all the actual ecu wiring, do the same to the aristo loom and then make a hybrid of the two so I have a supra loom using an aristo ecu and engine connector set any help would be greatly appreciated, I'm probably not searching for the right things Quote Link to comment Share on other sites More sharing options...
jonny mac Posted September 27, 2017 Author Share Posted September 27, 2017 are the connectors and plugs the same, just without the pins for the autobox ? being the difference between auto and manual looms? Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted September 27, 2017 Share Posted September 27, 2017 are the connectors and plugs the same, just without the pins for the autobox ? being the difference between auto and manual looms? Yes, Wilbro666 2JZGE page is like 99% accurate for the JSPEC NA manual/auto Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted September 27, 2017 Share Posted September 27, 2017 (edited) This any use to you jonny? http://www.mkivsupra.net/vbb/showthread.php?232824-J-Spec-Engine-Harness-Connector-Details&highlight=pinout http://www.mkivsupra.net/vbb/showthread.php?35919-ECU-Pinouts&p=2726447&viewfull=1#post2726447 http://www.mkivsupra.net/vbb/showthread.php?263818-1JZ-Project-Tips-and-Advice-Most-Welcome&p=3321971&viewfull=1#post3321971 Edited September 27, 2017 by pedrosixfour (see edit history) Quote Link to comment Share on other sites More sharing options...
jonny mac Posted September 28, 2017 Author Share Posted September 28, 2017 (edited) This any use to you jonny? http://www.mkivsupra.net/vbb/showthread.php?232824-J-Spec-Engine-Harness-Connector-Details&highlight=pinout http://www.mkivsupra.net/vbb/showthread.php?35919-ECU-Pinouts&p=2726447&viewfull=1#post2726447 http://www.mkivsupra.net/vbb/showthread.php?263818-1JZ-Project-Tips-and-Advice-Most-Welcome&p=3321971&viewfull=1#post3321971 thank you, some fantastic info there: http://www.mkivsupra.net/vbb/showthread.php?263818-1JZ-Project-Tips-and-Advice-Most-Welcome&p=3321971&viewfull=1#post3321971 on this post, is that the pinout of the supra bodyplug down by the ecu? I'm keen to find an exact pinout of the supra bodyplugs that connect to the dash loom beside the ecu unless they are the same plugs just missing the auto stuff between manual/auto cars? the wilbo jza80 ecu bodyplugs are a great reference just unsure how similar they are to a manual loom Edited September 28, 2017 by jonny mac (see edit history) Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted September 28, 2017 Share Posted September 28, 2017 thank you, some fantastic info there: http://www.mkivsupra.net/vbb/showthread.php?263818-1JZ-Project-Tips-and-Advice-Most-Welcome&p=3321971&viewfull=1#post3321971 on this post, is that the pinout of the supra bodyplug down by the ecu? I'm keen to find an exact pinout of the supra bodyplugs that connect to the dash loom beside the ecu unless they are the same plugs just missing the auto stuff between manual/auto cars? the wilbo jza80 ecu bodyplugs are a great reference just unsure how similar they are to a manual loom They are the same dude. Everything highlighted in blue on Wilbro666 is an automatic only wire and will be missing from a manual loom. It's as easy as that. The only interior plugs you will need to care about is the Orange & grey one. The small white one is only found on auto looms and dosen't control anything when using a manual. Quote Link to comment Share on other sites More sharing options...
jonny mac Posted September 28, 2017 Author Share Posted September 28, 2017 judging by this thread the ecu connectors are the same, so I'd assume the body plugs are the same, so just need to find an actual pinout for a manual body connector set ? http://www.mkivsupra.net/vbb/showthread.php?301787-Auto-and-manual-ecu-differnces Quote Link to comment Share on other sites More sharing options...
Konrad Posted October 2, 2017 Share Posted October 2, 2017 AFAIK Wilbo is pointing out what wire goes where, it does work for both manual and auto. As Mike said, auto will be marked and mentioned in info box Quote Link to comment Share on other sites More sharing options...
