Jonny's Supra Revival Project
jonny mac
  • Replies 72
Posted Images
moved the engine for more working access
image70 by Jonny McIntosh, on Flickr
swapped over the old supra steering wheel and now using a celica one, cheap and certainly alot nicer to drive with
image71 by Jonny McIntosh, on Flickr
image72 by Jonny McIntosh, on Flickr
keeping the space beneath stereo open for a gauge pod :D
pas pump on, just need to make up a bracket where the ac would go
image73 by Jonny McIntosh, on Flickr
started replacing the vacuum pipework around the turbos because they had all gone hard and brittle with age
image74 by Jonny McIntosh, on Flickr
new bearing in the aux belt tensioner pulley
image75 by Jonny McIntosh, on Flickr
got a water pump off my mate, it was a genuine toyota item that had done 3 weeks on a car and most of that was not even on the road, good as new, so i just replaced all the gaskets around it when fitting
image76 by Jonny McIntosh, on Flickr
my engine had the water pump done in japan usign an aftermarket brand, alot of the time they're actually just all from the same company as oem toyota use but have the toyota marks ground back
image77 by Jonny McIntosh, on Flickr
stripped
image78 by Jonny McIntosh, on Flickr
old o ring removed from block and new one put in, also both o rings on the tall water pipe
image79 by Jonny McIntosh, on Flickr
image80 by Jonny McIntosh, on Flickr
image81 by Jonny McIntosh, on Flickr
new temp sensor in too
image82 by Jonny McIntosh, on Flickr
made up some oil drain lines for the turbos, also heat protected one of them closer to the exhaust
image83 by Jonny McIntosh, on Flickr
thermostat back in and lower rad hose
image84 by Jonny McIntosh, on Flickr
so i'm at a bit of a tricky point now, i have a full set of valve stem seals i could fit but i don't know if the engine needs them yet
it'll be ALOT easier doing them just now rather than later though, i have the intention to use the rope trick like poormanmods on youtube did and that way you don't take the head off
if not, then this lot is going onto the engine tomorrow night
image85 by Jonny McIntosh, on Flickr
added the brake servo fitting for the intake manifold with new sealing washers
image86 by Jonny McIntosh, on Flickr
also replaced most of the vacuum pipes with new silicone hose
image87 by Jonny McIntosh, on Flickr
i need a rear sump dipstick tube! just remembered,
stripped the rocker covers and other parts off to access the stem seals
found some writing on the exh camshaft, not sure what that means
image88 by Jonny McIntosh, on Flickr
cams out, really clean in here :D
image89 by Jonny McIntosh, on Flickr
followed factory service manual for removal making sure to follow slackening procedure
image90 by Jonny McIntosh, on Flickr
used the poormanmods video on youtube and copied what he done, the rope trick
image91 by Jonny McIntosh, on Flickr
bucket and lifter off
image92 by Jonny McIntosh, on Flickr
image93 by Jonny McIntosh, on Flickr
one of 24 removed
image94 by Jonny McIntosh, on Flickr
during
image95 by Jonny McIntosh, on Flickr
new camshaft seals for both sides
image96 by Jonny McIntosh, on Flickr
old crap
image97 by Jonny McIntosh, on Flickr
new rocker cover gaskets going on
image98 by Jonny McIntosh, on Flickr
new belt on, turned vvti pulley fully clockwise then timed in correctly using the dash instead of the dot's on the pulleys once the crank was at tdc1
image99 by Jonny McIntosh, on Flickr
some new grade 7 copper plugs in
image100 by Jonny McIntosh, on Flickr
back together with no bolts on the blue cover as that needs to come back off for the loom
image101 by Jonny McIntosh, on Flickr
i still need to get the following:
dash gauge temp sensor
sump oil level sensor or blanking plate
air conditioning bracket to support power steering pump
wiring loom made up and fitted to the engine
r154 flywheel/clutch
Nice little project, well done for taking it on. Always nice to see another saved.
thanks, too many people taking these cars purely for breaking them
as I said to the guy I took it from, I couldn't bear to see a supra lay up not moving haha
my r154 arrived today :D woohoo!
so I need a few bits:
r154 slave cylinder
2jz bel housing for r154
r154 pull type pressure clutch cover
just ordered a new spigot bearing and I'm going to try get the flywheel resurfaced that came with my gearbox
Guest Cillian
love this build, followed your s14 build on sxoc over the years, still have my s14's too!
Most impressive part here is the amount of progress you make in a short space of time, great work!
  • 2 weeks later...
oh aye thanks, the s14 has been stored since it's insurance ran out in august, I've not had the time or the money to do anything with it just now as it's being consumed by this supra haha
update:
took my r154 flywheel for skimming since i'll be using a new clutch, had very little taken off so it's perfectly flat now, some of the original face is still there
image102 by Jonny McIntosh, on Flickr
went to fill the engine up with the new oil, using titan pro race 15w50, half filled the engine with that and will use an ordinary 5w50 comma motorsport oil for the rest just for the first start to run for 5 minutes then will drain and put in the titan pro race oil with another new filter
image103 by Jonny McIntosh, on Flickr
made a start at the aristo loom
cut out all of the autobox loom and labeled up which wires are +b etc
image104 by Jonny McIntosh, on Flickr
image105 by Jonny McIntosh, on Flickr
toyota r154 bel housing arrived
image106 by Jonny McIntosh, on Flickr
image107 by Jonny McIntosh, on Flickr
competition clutch organic r154 disc
image108 by Jonny McIntosh, on Flickr
toyota oem r154 clutch cover
image109 by Jonny McIntosh, on Flickr
toyota r154 slave cylinder
image110 by Jonny McIntosh, on Flickr
toyota release bearing
image111 by Jonny McIntosh, on Flickr
carpet cleaning
image112 by Jonny McIntosh, on Flickr
clutch hub washers arrived
image113 by Jonny McIntosh, on Flickr
bearing assembled onto hub
image114 by Jonny McIntosh, on Flickr
then complete unit into cover
image115 by Jonny McIntosh, on Flickr
got cracking on saturday morning and the sun came out too which was great as i was expecting to be freezing my nuts off
image116 by Jonny McIntosh, on Flickr
ready to lift and pull, my trusty old s14 wheels always used as jacks to lift the car up high enough, pulled many engines out with these supporting
everything disconnected that needed to be, i'd unbolted the exhaust manifold because the bolts were siezed into the cat and i didn't have my grinder or any form of heat
one side fell off so i guess that was where my exhaust leak up front was haha, a dead flexi join
image117 by Jonny McIntosh, on Flickr
so that's the ge and w58 out the way, i began using a degreasing and shampoo mix on the engine bay
image118 by Jonny McIntosh, on Flickr
image119 by Jonny McIntosh, on Flickr
still needs tidied but it's 100x cleaner than it was
image120 by Jonny McIntosh, on Flickr
engine out and laid carefully onto blocks of wood ontop of a caster frame
image122 by Jonny McIntosh, on Flickr
  • 2 weeks later...
not had alot of spare time recently, made a good dent into the wiring loom job however
extended every wire on the aristo ecu plugs through my mkiv n/a loom bullkhead grommit down to match ecu mounting position
image123 by Jonny McIntosh, on Flickr
serious amount of soldering done, heatshrink used on every join and also taped over the top for extra protection
here's a clearer picture of what's going on with the wiring now and where i'm up to
top left section is the vvti turbo aristo engine loom plugs
top right is mkiv n/a alternator, coolant temp dash sensor, starter solenoid, p/s switch, fuse box plugs and a few others required for the chassis
bottom left is all extended aristo ecu plugs with supra wires waiting to be joined in for ecu power, +b, mrel, power to coils and injectors, igsw, crank wire, rpm output etc
bottom right is mkiv body plugs so the orange and grey dash plugs giving various inputs/outputs required
so i need another evening's soldering and loom wrapping then hopefully it'll work fine, used the one main feed wire that was there originally for coils and injectors form the n/a and joined it into the coils/inj on the vvti loom as i figured my car already has a relay to switch those on, my s14 had one relay doing both coils and injectors and worked fine so should be ok in this
worst case is i just split the two main red power feeds and add 2 new 30amp relays to them
image124 by Jonny McIntosh, on Flickr
mk3 supra r154 front propshaft pieced together with the mkiv bearing carrier and flange for propshaft ready to go!
image125 by Jonny McIntosh, on Flickr
w58 is sold and posted
arp flywheel 4ag corolla bolts arrived
image126 by Jonny McIntosh, on Flickr
rear main seal
image127 by Jonny McIntosh, on Flickr
rear spats arrived
image128 by Jonny McIntosh, on Flickr
Edited by jonny mac (see edit history)
  • 3 weeks later...
will be updating this soon with more pics of what's going on, decided to remove the ac rad from car and pump from engine, never use ac myself and the rad was not in the best condition anyway
here's my to do list:
finish wiring
oil level sensor gasket + refit into sump
dipstick new o ring plus refit into sump
sandwich plate gauge senders to fit then bolt to engine
remove engine stand and lay engine onto a tyre for fitting gearbox
rear main seal
flywheel
clutch+gearbox onto engine
attach loom to engine before fitting to car
go over every vacuum line again and jubilee clips for water pipes
fit alternator
fit aux belt
fit coolant temp sensor for dash on supra
my whifbitz 3" 2nd decat arrived, I also have now got to make a custom front decat as the aristo one doesn't look like it'll work due to the flange and angles being different to the supra mkiv system
I've also been looking at intercooler pipework and because the aristo twin's come out at a different angle it's looking like a custom top pipe will be needed also
getting there slowly but the weather sucks and I have very limited time just now due to busy family life!
some of you may fancy a look at my other project car I've recently 'finished' back in august after many years
http://www.mkivsupra.net/vbb/showthread.php?346240-1-5JZ-Forged-S14-Silvia&p=4250155#post4250155
forgot to upload this pic of my r154, it is from a jzx100 so had remote shifter which fits the mkiv perfectly
image129 by Jonny McIntosh, on Flickr
alternator quickly tidied up
image130 by Jonny McIntosh, on Flickr
new bel housing going on from toyota
image131 by Jonny McIntosh, on Flickr
image132 by Jonny McIntosh, on Flickr
dash coolant temp sensor new from toyota
image133 by Jonny McIntosh, on Flickr
air con bracket and alternator on the engine now
image134 by Jonny McIntosh, on Flickr
found a dipstick that'll work from another rear sump, also put in the level sensor
it has been painted and tidied up also
image135 by Jonny McIntosh, on Flickr
solid shifter bushes for the r154 tripod
image136 by Jonny McIntosh, on Flickr
also tidied up the r154 box with some paint before it's put on the engine
image137 by Jonny McIntosh, on Flickr
took advantage of the black friday deals and saved £20 on a decat pipe from garagewhifbitz
  • 2 weeks later...
I love revivals like this! Bringing it back from the dead. There is 2 supras in the same condition by my work in oldbury, infact 1 is worse. There is a black 1 which is now green with moss/ algae and a white 1 which was also green but is has had 1 wash of what i know off in the last 5 years. Both motors have not moved at all and both are with 1 mile of each other! Such a shame, the white 1 looks pretty smart, its got gold bbs wheels on it too
thanks, yeah they sound a bit far gone, I'd easily take them and try though haha, the black one I have I guessi just got lucky that it wasn't rotten, nothing like a gamble haha
I believe pictures of the white one were doing the rounds at one point. Story was the guy's son originally owned the car, but sadly passed away. Apparently they would always clean it together and so after he passed the father never washed it again, but would often be seen driving around in it.
How much of that is true I don't know.....
Thats tragic if it is the case, ive done a little digging and im sure he was a member on here called crashoverride but not been active for a long time. Sorry to go off topic
Happy new year!
unfortuantely i've not had a chance to do anything really, family life has been non stop lately so i've not had any spare time to get near stuff
here's just a few things i've managed with the 5 minutes a week i've had spare :S
oil level sensor in
dash temp gauge in, along with the new ecu temp sensor
thinking about it, i should have had a 1/8th npt bung welded onto the water neck for an aftermarket gauge sender
nevermind i'll just have to run one inline in the top hose
chopped up ac pump used as pas bracket support like intended from original setup
and lastly swapped out the na throttle cable for a TT one
the situation right now is i don't have the space to lift the engine off the stand and fit the rear main seal/flywheel/clutch/gearbox
the reason being, it'll literarly have to be put in the car the same day as i wont get my garage door shut with the engine/box combo together
but before i do that....i still have some work to do to the engine bay, i'd like to rub back a few small bits and tidy it up
my brake servo needs a rub back and painted too, along with the radiator crossmember so i'm just waiting on a nice dry weekend now to get all that done
once the car is ready, then i'll just be waiting on a day i have good weather and a free saturday to get working on the car!
  • 3 weeks later...
