RobSheffield Posted September 27, 2005 Share Posted September 27, 2005 bought 9006 bulbs from halfords and they dont blody fit - the lumps dont fit where they should, and it seams to be too big for the hole Quote Link to comment Share on other sites More sharing options...
Jake Posted September 27, 2005 Share Posted September 27, 2005 Rob, See my post in this thread from earlier today: http://www.mkivsupra.net/vbb/showthread.php?t=48125 Quote Link to comment Share on other sites More sharing options...
Pete Posted September 27, 2005 Share Posted September 27, 2005 9006J. Otherwise you end up filing some. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted September 27, 2005 Author Share Posted September 27, 2005 ok, so Jake says 9005 in high/main beam, and your saying 9006J mr Rogue?! which one is it to be?! Quote Link to comment Share on other sites More sharing options...
Pete Posted September 27, 2005 Share Posted September 27, 2005 ok, so Jake says 9005 in high/main beam, and your saying 9006J mr Rogue?! which one is it to be?! Believe Jake. It's been a while since I looked. Either way the Halfords ones will be too fat and you'll end up making the plastic thinner around the edge (well I always do) I always get them mixed up and keep both in the garage just in case anyway! Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted September 27, 2005 Author Share Posted September 27, 2005 Believe Jake. It's been a while since I looked. Either way the Halfords ones will be too fat and you'll end up making the plastic thinner around the edge (well I always do) bugger! all im tryin to do is make my main beam and fogs like the HIDS i have on my dipped beam - why do halfrauds insist on making it so damn hard! anyone found a decent foglight bulb thats blue? Quote Link to comment Share on other sites More sharing options...
Steve W Posted September 27, 2005 Share Posted September 27, 2005 The JAP bulbs are diff' cos of the smaller/diff' 3 lugs. BUT, the UK 9005 bulb WILL fit both High and Dip Jap holes if you just shave/ file the 3 lugs SLIGHTLY to allow it to fit. You're right, the 9006 base IS too big for the Jap holes so CAN'T use it I've got UK 9005 90w Blue/Whites in my Jap HIGH. They give PURE White light but only slightly "stronger" cos the bluey glass actually cuts the light down a bit anyhow.... MUCH better than the normal bulb though ! ! Haven't actually PUT the 9005 in my DIP yet,. i KNOW it fits but not 100% sure the beam pattern will be OK. I WILL be trying just that soon though cos fed up with the dip "yellowness" when compared with the HIGHS now (funny, they seemed perfectly OK till i got the Blue-White ones ??) FatS. Quote Link to comment Share on other sites More sharing options...
Nic Posted September 27, 2005 Share Posted September 27, 2005 Correct J-spec bulb specs are: Low = 9006J High = 9005J However the J bulbs are not available in the UK. The problem is that the 9006J and 9006 have different diameter bodies (20mm and 22mm respectively, see diagram). To get around this what you can do is to fit a 9005 (HB3) bulb in the high AND low beams (you will need to slightly modify the connector to make them fit though) Not a problem on the UK spec as they are: Low = 9006 (HB4) High = 9005 (HB3) Quote Link to comment Share on other sites More sharing options...
Steve W Posted September 27, 2005 Share Posted September 27, 2005 PS i tried the NORMAL wattage "Blue" bulbs and all they did was give LESS light ?!?!?!? The High wattage ones bring it back up AND whiter. Only SLIGHT doubt is that the DIP bulb has to sit close to the "projector" bit ?? maybe the higher wattage / heat will be too much for the glass ??? (not a problem with the HIGH obviously !) Would have SAME prob (?) with the FOG. . . PROJECTOR bit !? Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted September 27, 2005 Author Share Posted September 27, 2005 im looking to be 'bluer' though Steve - since i got HIDS in the dipped bit Quote Link to comment Share on other sites More sharing options...
Steve W Posted September 27, 2005 Share Posted September 27, 2005 AND does it matter that the UK 9006 has the blackened TIP ? ? obviously using a 9005 in its place will mean lack-of-tip... Is it important ? - for the beam ? Quote Link to comment Share on other sites More sharing options...
Nic Posted September 27, 2005 Share Posted September 27, 2005 ....and for my next specialist subject HID kits; good quality kits and bad quality kits. Have I not sold you an HID kit yet Rob? and if not why not The HID bulbs will fit in the 'ole with no modifying required and turn night into day Quote Link to comment Share on other sites More sharing options...
Steve W Posted September 27, 2005 Share Posted September 27, 2005 If you get strongly BLUEd glass and just the 55/60 watts it WILL be Blue to a certain degree. My ones are a pale blue and actually come out WHITE (no blue light at all) Although when you look into headlight in daylight the BLUEness is VERY easy to see (and you might say looks odd ???) (with them OFF i mean - just the LOOK in the reflector) Quote Link to comment Share on other sites More sharing options...
Nic Posted September 27, 2005 Share Posted September 27, 2005 AND does it matter that the UK 9006 has the blackened TIP ? ? obviously using a 9005 in its place will mean lack-of-tip... Is it important ? - for the beam ? Seems fine, actually slightly brighter so I'd say they were better. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted September 27, 2005 Author Share Posted September 27, 2005 Have I not sold you an HID kit yet Rob? and if not why not The HID bulbs will fit in the 'ole with no modifying required and turn night into day im glad you can remember! the HIDS i have on my dipped beam since i got HIDS in the dipped bit see - i have HID's, you supplied them, they are nice - thankyou! Quote Link to comment Share on other sites More sharing options...
Steve W Posted September 27, 2005 Share Posted September 27, 2005 BUT, not even my high wattage bulbs are anywhere NEAR the light output of the HIDs. Bit silly really, my bulbs are ILLEGAL cos they're too high a wattage, BUT, they are less BLINDING than "LEGAL" HIDs ?!?!?!?!?!?!?!?!? METHINKS the law is a bit out of date Quote Link to comment Share on other sites More sharing options...
Nic Posted September 27, 2005 Share Posted September 27, 2005 Rob the 9005's should fit in the 9005J hole? I thought your were talking about problem with dipped beam but just re-read your post. I thought I'd sold you some HID's already Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted September 27, 2005 Author Share Posted September 27, 2005 I thought I'd sold you some HID's already you HAVE!!!! Quote Link to comment Share on other sites More sharing options...
Nic Posted September 27, 2005 Share Posted September 27, 2005 im glad you can remember! see - i have HID's, you supplied them, they are nice - thankyou! I thought I had, I just got confused as I thought you were having problems with the fit of the low beam bulb. I'm still awake but my brain dozed off hours ago Quote Link to comment Share on other sites More sharing options...
Paul Posted September 27, 2005 Share Posted September 27, 2005 you HAVE!!!! Rob, did Nic flog you some HID's by any chance? Can't wait to get mine and fit them now. Quote Link to comment Share on other sites More sharing options...
Nic Posted September 28, 2005 Share Posted September 28, 2005 Rob, did Nic flog you some HID's by any chance? Can't wait to get mine and fit them now. Have I sold you some too? Quote Link to comment Share on other sites More sharing options...
