OEM wheel nuts
AC93
I'd be concerned about the ebay ones, the material listed just says toughened steel, i'd rather see what they are made of specifically
This advert is better but no idea if they are any better than others listed, personally
unless i found OE or OEM quality i'd suffer buying Toyotas
http://www.ebay.co.uk/itm/Set-of-20-x-M12-x-1-5-21mm-Hex-Flat-Seat-Toyota-Alloy-Wheel-Nuts-Silver/172023180427?_trkparms=aid%3D888007%26algo%3DDISC.MBE%26ao%3D1%26asc%3D46150%26meid%3D108be54f8b6c42558f44f7976e63c6c4%26pid%3D100009%26rk%3D1%26rkt%3D1%26sd%3D130679954320&_trksid=p2047675.c100009.m1982
I had the same quandary last year, i ended up buying these off eBay so i could fit my Uk specs over winter...
http://www.ebay.co.uk/itm/16-x-original-spec-M12-x-1-5-21mm-Hex-flat-Seat-O-E-style-alloy-wheel-nuts-lugs-/261863512106?hash=item3cf848182a:g:XWQAAOSwqu9VOOsy
16 due to having 4 locking wheel nuts.
Quality wise they are just fine, solid construction and no signs of corrosion etc over a full winters use.
Worth trying a local breakers. I paid £20 for a set a couple of years back, all good as new.
Good shout, there's one not far from me so will pop in tomorrow
Ahh cheers, will order these if I can't get any from the local breakers
  • 1 year later...
I will have a look to see if I have 20 spare!
That'll be great if you have. Even better if they can be posted pronto. I need to buy tyres and don't want to buy any for the aftermarket wheels on there currently. I'm going away in it a week on Saturday :)
