machman Posted September 17, 2017 Share Posted September 17, 2017 I have an auto j spec TT, are the UK spec shocks the same, do they fit and provide the same handling? Quote Link to comment Share on other sites More sharing options...
AC93 Posted September 17, 2017 Share Posted September 17, 2017 Do you have the yellow Toyota Bilstein ones? Quote Link to comment Share on other sites More sharing options...
Tyson Posted September 17, 2017 Share Posted September 17, 2017 I have an auto j spec TT, are the UK spec shocks the same, do they fit and provide the same handling? /QUOTE] Uk shocks are not the same they are softer than jspec. Quote Link to comment Share on other sites More sharing options...
machman Posted September 17, 2017 Author Share Posted September 17, 2017 I thought that might be the case! Quote Link to comment Share on other sites More sharing options...
fastcar Posted September 17, 2017 Share Posted September 17, 2017 The yellow bilstien shocks will be the same whether UK or J spec it's the springs that are different as in J Specs are stiffer Quote Link to comment Share on other sites More sharing options...
Spunkmeyer Posted September 18, 2017 Share Posted September 18, 2017 They might be blue badged (German) rather than red badged (OEM) and can be repaired and revalved by CW Quote Link to comment Share on other sites More sharing options...
machman Posted September 19, 2017 Author Share Posted September 19, 2017 Do you have the yellow Toyota Bilstein ones?No they're the standard black ones, leaking oil hence why I'm looking at my options. I will probably replace them with Blitsteins, I'm want to retain the standard setup or improve on it slightly without major modifications. . . Quote Link to comment Share on other sites More sharing options...
Tyson Posted September 19, 2017 Share Posted September 19, 2017 The yellow bilstien shocks will be the same whether UK or J spec it's the springs that are different as in J Specs are stiffer Uk and jspec shocks have different part numbers so I assumed they were different. Quote Link to comment Share on other sites More sharing options...
Burna Posted September 19, 2017 Share Posted September 19, 2017 The yellow bilstien shocks will be the same whether UK or J spec it's the springs that are different as in J Specs are stiffer UK's didn't come with yellow bilstiens, they came with black softer shocks, they are very Boaty Mc Boatface in the corners! Quote Link to comment Share on other sites More sharing options...
Scooter Posted September 19, 2017 Share Posted September 19, 2017 No they're the standard black ones, leaking oil hence why I'm looking at my options. I will probably replace them with Blitsteins, I'm want to retain the standard setup or improve on it slightly without major modifications. . . /QUOTE] Yellow Bilsteins will do just that, I got mine from Germany via ebay, about £125 each. Quote Link to comment Share on other sites More sharing options...
machman Posted September 19, 2017 Author Share Posted September 19, 2017 Yellow Bilsteins will do just that, I got mine from Germany via ebay, about £125 each.That gives me confidence, will go ahead with Bilsteins. Cheers for the input everyone Quote Link to comment Share on other sites More sharing options...
Scooter Posted September 19, 2017 Share Posted September 19, 2017 I had black (probably original) shocks on one of mine and just out of the village is a double dip, one where the car comes down after the first hump and is compressed as it hits the next and you'd get flung around. After the yellow bilsteins it was a lot more composed/controlled noticeably less deflection up and down! Quote Link to comment Share on other sites More sharing options...
fastcar Posted September 19, 2017 Share Posted September 19, 2017 Uk and jspec shocks have different part numbers so I assumed they were different. I stand corrected sir, you are right:cool: Quote Link to comment Share on other sites More sharing options...
Burna Posted September 20, 2017 Share Posted September 20, 2017 That gives me confidence, will go ahead with Bilsteins. Cheers for the input everyone /QUOTE] Good choice Quote Link to comment Share on other sites More sharing options...
