a98pmalcolm Posted September 16, 2017 Share Posted September 16, 2017 Hi Guys I have just fitted a new cambelt and water pump but I am also upgrading to a Fluidamper crank pulley. The OEM crank uses 2 bolts to hold the tool to keep it still but a Fluidamper has three.. How will I hold the pulley tight? Any advice anyone? Thanks OEM Pulley (with 2 holes to bolt the pulley holder): Fluidamper (with 3 holes to bolt a pully holer): Quote Link to comment Share on other sites More sharing options...
Scooter Posted September 16, 2017 Share Posted September 16, 2017 I think as you are manual you can pop it in gear (a high one from memory i think is best?) and have the handbrake on (and an assistant to hold the brake perhaps) Quote Link to comment Share on other sites More sharing options...
Rob W Posted September 16, 2017 Share Posted September 16, 2017 Yep unfortunately you can't use the Toyota crank pulley tool with the fluidampr, I had to make my own locking tool up. Quote Link to comment Share on other sites More sharing options...
Sheefa Posted September 17, 2017 Share Posted September 17, 2017 I think as you are manual you can pop it in gear (a high one from memory i think is best?) and have the handbrake on (and an assistant to hold the brake perhaps) Yep. I'm sure Littlenum did this with mine mate we didn't need a tool. Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted September 17, 2017 Author Share Posted September 17, 2017 Thanks for the reply fellas. Fab idea scooter Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted September 17, 2017 Author Share Posted September 17, 2017 190ftlb so far. Dont think i can get anymore lol Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted September 17, 2017 Author Share Posted September 17, 2017 Done Quote Link to comment Share on other sites More sharing options...
Sheefa Posted September 17, 2017 Share Posted September 17, 2017 Did you do it using above method mate? Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted September 17, 2017 Author Share Posted September 17, 2017 Yes mate. Into gear and handbrake on. But got to a point were someone had to press on the brake pedal Quote Link to comment Share on other sites More sharing options...
