Fostas bolt in roll cage for aerotop
Lewmc93
How much modification is needed to get this to fit?
/QUOTE]
Just a little trim on the plastics near the rear speakers and drilling it in or welding.
If picked up I could swap the cut plastic pieces with buyers so they have perfectly placed cut holes anywya , but obviously that's up to them
Spoken for me ! All mine has is bolt holes or as suggested welded in for better rigidity.
It's also thicker piping than the cusco piping I believe
Out of interest, how much does it reduce the scuttle shake?
Would it at all? The aero cages are just at the rear, they don't cross the weak part in the middle so i can't see how it would reduce it much if at all? You'd need a full cage for that?
