Facelift LED rear light PCB's and Facelift Dial PCB's
heckler
  • 1 month later...
Just having bit of a clear out... Facelift LED rear light PCB's fully painted (un-drilled) - £80 or can build up with components for additional cost.
Facelift, single colour Dial PCB's drilled £50 - or built up with components for £90https://uploads.tapatalk-cdn.com/20170907/ec20838b348bdd3d93e166de238718b2.jpghttps://uploads.tapatalk-cdn.com/20170907/499ed94df6df40bc1ac501fa8f0e1ccf.jpg
/QUOTE]A quick bump.. still have the rear light PCB's! - the last ones i will ever make!!
Heckler , while you are online :) My heater control unit has stopped working , What would you recommend , can I run some sort of checks to see it is completely gone
does it light up, has all the functions stopped working? - could be dry solder joints on the pcb where the connectors attach
All Functions are gone , leds on it have started failing over the last year; when I turn the lights on , LEDs still remaining may come on for 2-3 secs but it is very intermittent behaviour
PITA now, if it rains as I cannot turn on the demister
Was looking out for 2nd hand units but need to check the loom wiring too
Any advice before I pull it out , I am not too sure if these are a common item to fail
just sounds like old age. More than likely its the control unit - just replace it.
Sorry to hijack Si :innocent:
Carlo, I have a spare unit, I bought it with the intention of sending it to Si for a blue led conversion without having to remove my own unit, but didn't get round to it and now sadly (been kicking myself over this one lol) it's too late.
You're welcome to it bud if you're still looking one, pm your address and I'll send it down to you :)
