Wavy graph on my boost controller
squiffy
I have fitted a greddy oled boost controller and as you can see from the picture im getting an interesting curve when the 2nd turbo comes In!
It's set to run around 18psi
I figuree the car was fighting the boost controller so did some searching on here and found the diagram about capping off the ports on the actuator and vsv. I have done that but now I am only getting 11 psi when I'm flat out and the car is noticeably slower.
However I now get the correct shaped graph
I've tried turning the boost up but it won't increase...
If anyone can shed any light on this it would be much appreciated
  • 1 month later...
