swap or p/ex my RX7 for you Sup?
looneytune
Took me a while to find your pics! Looks good, i like the exhaust manifold!
have you got any recent pics with the new wheels?
How many miles has it done, whats the full spec, tax & ticket? Overall condition?
cheers
stuart
Sorry forgot! 6 months tax and ticket left.
As to spec:
Supra SZ, Aircon (works) PAS, EW, Power drivers seat.
The upgrades are on the bottom of my signature. Hope this helps.
Regards your car:
Did you do the compression test yourself as the numbers are a little askew. I used to have a 7, the rear cylinder is within the upper limit of difference. Did you take the test on three seperate occasions, or was that the numbers you recording on three sucessions of cranking over?
I am blissfully aware of the 13B's ability to destroy itself, how many miles have you done since owning it and what oil do you use?
Remind me of the mileage again, has it got the restrictor fitted and do you have it serviced regularly?
Cheers buddy.
i did the compression test & watched the needle bounce on the guage, it took a few attempts to get the 3 seperate readings for each rotor & they are by no means 100% accurate but definatly with 0.1 bar of being accurate.
The cars done 82000kms so about 51000miles. i change the oil very regularly (2000 miles) for castrol gtx mineral oil & change the filter on every other oil change. As soon is it arrived in the uk it was checked over by DS Engineering who are a local rx7 specialist, i was told it was in very good & clean condition & all that was needed was new spark plugs, air filter & some new vacuum pipes, it has a very very minor oil leak where the pipe goes into the oil cooler but not big enough to be noticable.
Its working perfectly & needs nothing doing to it.
Oh I forgot my car has some large double din, CD and MD player.
How are you getting on with the interest with your car on the mazdarotary forum?
I am sorely tempted with a swap despite the fact I will go from 25mpg to 12mpg! No back seats, but who cares!
Im interested but really would prefer a black one, im looking into the cost of a respray in black at the moment, as long as its reasonable id be very interested in a swap.
What year is yours and have the headlight covers gone milky yet?
can you pm me your reg number so i can double check elephant will cover me?
  • 2 weeks later...
