Marty Posted August 21, 2017 Share Posted August 21, 2017 not like this no? take a look at this thread.. http://www.mkivsupra.net/vbb/archive/index.php/t-226591.html Quote Link to comment Share on other sites More sharing options...
HITESH Posted August 21, 2017 Share Posted August 21, 2017 Hi All I have some knock sound in the front suspension, it can come and goes, and only when turning.. i have changed the adjustable suspension from h&r.. but had the knocking sound too the the other suspension.. what parts should i get a look at??? had the same problem on mine for years, turned out to be LOWER CONTROL ARM BUSHES!. The big bolt that goes through the arm seizes up in the metal insert in the bush. undo the nut on the end, blast loads of oil into the joint then lower/raise the car couple of times on its wheels and it should loosen up! Quote Link to comment Share on other sites More sharing options...
jza800 Posted August 22, 2017 Author Share Posted August 22, 2017 No not like that.. it is more like a squeak sound.. not klonk.. and sound like it goes away when braking... Quote Link to comment Share on other sites More sharing options...
jza800 Posted August 22, 2017 Author Share Posted August 22, 2017 had the same problem on mine for years, turned out to be LOWER CONTROL ARM BUSHES!. The big bolt that goes through the arm seizes up in the metal insert in the bush. undo the nut on the end, blast loads of oil into the joint then lower/raise the car couple of times on its wheels and it should loosen up! Did that only klonk or did it squeak ??? Quote Link to comment Share on other sites More sharing options...
jza800 Posted August 23, 2017 Author Share Posted August 23, 2017 bump Quote Link to comment Share on other sites More sharing options...
jza800 Posted August 25, 2017 Author Share Posted August 25, 2017 this is the sound i have https://youtu.be/LO9cfF8WAD8 Quote Link to comment Share on other sites More sharing options...
AC93 Posted August 25, 2017 Share Posted August 25, 2017 Bloody heck that sounds a bit patchy. Does it make a difference when turning or braking? Quote Link to comment Share on other sites More sharing options...
jza800 Posted August 25, 2017 Author Share Posted August 25, 2017 Yes when i brake is sound like it close to disappears.. and is it only when turning.. at straight road or roadbumps. nothing at all.. Quote Link to comment Share on other sites More sharing options...
jza800 Posted August 26, 2017 Author Share Posted August 26, 2017 Pretty sure i did found the problem now, the lower control arm ball joint have dried out.. any body else had that problem???? Quote Link to comment Share on other sites More sharing options...
Tyson Posted August 26, 2017 Share Posted August 26, 2017 Pretty sure i did found the problem now, the lower control arm ball joint have dried out.. any body else had that problem???? These cars are at an age where suspension bushes are becoming worn and need replacing. Lots of people doing or wanting to do suspensions rebuilds to future proof thier cars before parts disappear. Quote Link to comment Share on other sites More sharing options...
jza800 Posted September 2, 2017 Author Share Posted September 2, 2017 Problem solved. it was the lower control arm ball joint that did make that sound... happy man but with a bill on 900 usd for 2 new control arms Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 2, 2017 Share Posted September 2, 2017 I would happily pay 900 USD to stop my missus making a bloody noise... Quote Link to comment Share on other sites More sharing options...
shaky Posted September 2, 2017 Share Posted September 2, 2017 I would happily pay 900 USD to stop my missus making a bloody noise... I had to pay a lot more than that !! Quote Link to comment Share on other sites More sharing options...
jza800 Posted September 2, 2017 Author Share Posted September 2, 2017 I would happily pay 900 USD to stop my missus making a bloody noise... Yes i now, it was only for fun parts get rarely and the cost off the part go up.. sad that toyota dont have so many parts back to supras.. Quote Link to comment Share on other sites More sharing options...
Dnk Posted September 2, 2017 Share Posted September 2, 2017 Problem solved. it was the lower control arm ball joint that did make that sound... happy man but with a bill on 900 usd for 2 new control arms Whats their part numbers, toyodiy i think have them listed for a lot less than that, 300 euro each Quote Link to comment Share on other sites More sharing options...
