Dzowani Posted August 15, 2017 Share Posted August 15, 2017 I have a problem with my active spoiler it does not work when the car is running when i turn of the car and switch half way the ignition i works then i turn on the car and it stops working even the button lights dont turn on. Did anybody have this kind of problem? Link to comment Share on other sites More sharing options...
fastcar Posted August 15, 2017 Share Posted August 15, 2017 Was this a fitment from factory or a retro fit? Link to comment Share on other sites More sharing options...
Dzowani Posted August 15, 2017 Author Share Posted August 15, 2017 Factory bud. When the engine is on it does not work i have to take out the key and put in back in with out turning on the engine and it works perfectly. Link to comment Share on other sites More sharing options...
kitch79 Posted August 15, 2017 Share Posted August 15, 2017 I used to think mine was dodgy. Then I was told it come down at a certain speed, one at 0mph with engine running. No matter what, it'll be tucked away. One of guys on here makes (or did) a box of tricks to correct this. Get someone to drive in front of u at around 50-60 mph and watch for it working. Link to comment Share on other sites More sharing options...
samdale Posted August 15, 2017 Share Posted August 15, 2017 The method you're describing I believe is there so you can clean the blade. The only way to have it down with the engine running and at low speeds is to fit an aftermarket override switch. It comes down automatically at >60mph-ish Link to comment Share on other sites More sharing options...
214supra Posted August 15, 2017 Share Posted August 15, 2017 The blade only deploy with the ignition on. Once you started the engine it will go back up, and come on once over 60mph with the green light on the switch. Link to comment Share on other sites More sharing options...
AC93 Posted August 15, 2017 Share Posted August 15, 2017 As above, comes down at 60mph unless you fit an override switch Link to comment Share on other sites More sharing options...
shaky Posted August 15, 2017 Share Posted August 15, 2017 Green light should come on about 60, then up it goes when you slow down, AndrewOW made the active spoiler manual override module Link to comment Share on other sites More sharing options...
Dzowani Posted August 15, 2017 Author Share Posted August 15, 2017 (edited) That makes sense now thanks for the info Edited August 15, 2017 by Dzowani (see edit history) Link to comment Share on other sites More sharing options...
