Guest capsot Posted August 6, 2017 Share Posted August 6, 2017 (edited) Hello Please can some kind owner answer this for me? I am disabled and use a mobility scooter. I am currently in Cardiff but keep a Supra 3.0 litre twin turbo 1993 LHD in Spain. Getting more difficult to use it - parking, limping etc. I have the chance to buy a second hand scooter here in Cardiff hoping I could take it to Spain and it would fit in the Supra with the back seat rest pushed forward. Would the broken down scooter still fit in the rear end of the Supra - please? I'm afraid it might be too tight length against height. Dimensions of scooter parts are Body 33" length with a height of 17" and width 19" Seat height 21" length with a width 22" and depth 20" Separate battery and separate back detachable traction unit would be no problem. It's the above components I don't know whether they could foul the back window - not enough clearance. If you have a Supra and could just check for me I would be so grateful. Thanks Bob Gregory Cardiff Edited August 6, 2017 by capsot (see edit history) Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted August 6, 2017 Share Posted August 6, 2017 Another idea could be to remove the passenger seat. I did this once and managed to fit an entire rear subframe assembly plus two front wings in the car with ease Quote Link to comment Share on other sites More sharing options...
mc92 Posted August 6, 2017 Share Posted August 6, 2017 The biggest thing I have put in my Supra was 18"h by 18"w by 38"l and that was quite tight. The height is the issue here, I don't think 21" will go in unless you put it on the front seat. Quote Link to comment Share on other sites More sharing options...
Guest capsot Posted August 6, 2017 Share Posted August 6, 2017 Another idea could be to remove the passenger seat. I did this once and managed to fit an entire rear subframe assembly plus two front wings in the car with ease I'd like to say a big thank you to both answer respondents. I can't remove the passenger seat unless I have my wife consigned to the local buses. Not a good idea! From what you wrote, it would seem that the body of the scooter would go in (33"x17"x19"). Would the seat height of 21" (would be separate from the body) go in if that part of the seat was hard up against the front seats please? Would you still think probably not? Thanks again. Quote Link to comment Share on other sites More sharing options...
mc92 Posted August 6, 2017 Share Posted August 6, 2017 I just measured and the highest point is about 19" with the back seat folded down. If you took the backrest of the rear seats out it might work. Quote Link to comment Share on other sites More sharing options...
Hitbox Junkie Posted August 6, 2017 Share Posted August 6, 2017 Would a electric wheel chair be smaller than a scooter? Dunno if you can get smaller electric scooters? Other than that could try to get a rack made up to hang it off the back of the car like a bike rack but for the scooter. Removing all the back seats could give you the room you need. Quote Link to comment Share on other sites More sharing options...
Guest capsot Posted August 7, 2017 Share Posted August 7, 2017 Thank you again for your kind responses and suggestions. It seems like a no-no for a broken down scooter in the back. I wouldn't want to remove the back seats altogether. I was hoping that folding down the back seats back rest to extend the horizontal space available would be enough but looks like it wouldn't be. All Best. Quote Link to comment Share on other sites More sharing options...
Dnk Posted August 7, 2017 Share Posted August 7, 2017 (edited) Do you have a photo of your scooter ? I'm Interested to see how the seat fits to it and the seat itself regarding its frame and how its constructed Before you give up i'm just wondering if you could modify the seat or make a custom seat to fit it that's in say two pieces, the base you sit on and the back support. Anything can be done with a little out of the box engineering Edited August 7, 2017 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest capsot Posted August 7, 2017 Share Posted August 7, 2017 Yes, OK - I can do some photos of the broken down components when I have some help tomorrow. Thanks - I'll be back with photos. I think the steel extension of the seat is going to be the problem but let's see. Quote Link to comment Share on other sites More sharing options...
Guest capsot Posted August 8, 2017 Share Posted August 8, 2017 Here are the photos of the broken down components. I think the attached metal rod on the bottom of the seat which slots into a hole in the body is going to be the main problem. Any further thoughts please? Quote Link to comment Share on other sites More sharing options...
Annabella Posted August 8, 2017 Share Posted August 8, 2017 Could you not put the components that won't fit in the boot ON the back seat? If you're OK to lift it/them out again? Quote Link to comment Share on other sites More sharing options...
shaky Posted August 8, 2017 Share Posted August 8, 2017 Why not just buy a sports chair with electric hubs ? simple. Quote Link to comment Share on other sites More sharing options...
Dnk Posted August 9, 2017 Share Posted August 9, 2017 Just unbolt the plate, looks like its fixed to the base of the seat with 4 Allen key bolts so wouldn't take long to do Quote Link to comment Share on other sites More sharing options...
jagman Posted August 9, 2017 Share Posted August 9, 2017 Or modify the supra drivers seat - so it's held into the car seat rails by quick release pins and adapt your mobility seat mount to fit below the supra seat - you then remove the drivers seat and fit to your mobility drive part (which you keep in the boot ), again using quick release pins Quote Link to comment Share on other sites More sharing options...
Hitbox Junkie Posted August 9, 2017 Share Posted August 9, 2017 would it be legal to fit your mobility scooter chair as the drivers chair? would be a good mod for you as it would save space in the supra for you too. Quote Link to comment Share on other sites More sharing options...
Dnk Posted August 9, 2017 Share Posted August 9, 2017 would it be legal to fit your mobility scooter chair as the drivers chair? would be a good mod for you as it would save space in the supra for you too. Quote Link to comment Share on other sites More sharing options...
Guest capsot Posted August 10, 2017 Share Posted August 10, 2017 Thanks to you all for further kind suggestions. Modifying the driver's seat is definitely not on but I tried the suggestion of takng the plate and tube extension off the bottom of the scooter's seat. It was a bit laborious but that might work. Unfortunately I would have to do this by bending down and the problem in the first place is a spinal one. I was thinking that with my wife's help I could manage to lift the components in/out of the rear gate but that's about all. Anyway, I have decided to buy this small scooter and take it to Spain with us next time and hope for the best. Thaks -again - everyone. Quote Link to comment Share on other sites More sharing options...
