U.K. Brake part numbers!
fastcar
does anyone know the part numbers for the following?
UK Caliper front left side and right side
UK front disc and pads
UK Caliper Rear left side right side
UK rear disc and pads left and right side
Thanks in advance
These should be the uk spec brake stuff for you Gav :thumbs:
CYLINDER ASSY, FRONT DISC BRAKE, RH - 47730-14260
CYLINDER ASSY, DISC BRAKE, LH - 47750-14270
PAD KIT, DISC BRAKE, FRONT - 04465-14150
SHIM KIT, ANTI SQUEAL, FRONT - 04945-14110
FITTING KIT, DISC BRAKE, FRONT - 04947-14010
DISC, FRONT, RH - 43512-14200
DISC, FRONT LH - 43516-14030
CYLINDER ASSY, REAR DISC BRAKE, RH - 47730-14270
CYLINDER ASSY, DISC BRAKE, REAR LH - 47750-14280
PAD KIT, DISC BRAKE, REAR - 04466-14040
SHIM KIT, ANTI SQUEAL(FOR REAR DISC BRAKE) - 04946-14030
FITTING KIT, DISC BRAKE, REAR - 04948-14010
DISC, REAR - 42431-14150
Edited by drift_bear (see edit history)
