Keith C Posted September 27, 2005 Share Posted September 27, 2005 ...in facelift lights? Got some free ones for signing up to Evo, and being the kind, caring husband I am I'm donating them to Faye, so just need to know what bulbs she needs. Ta Quote Link to comment Share on other sites More sharing options...
Keith C Posted September 27, 2005 Author Share Posted September 27, 2005 Anyone? Quote Link to comment Share on other sites More sharing options...
Jake Posted September 27, 2005 Share Posted September 27, 2005 Front or rear facelift lights? Quote Link to comment Share on other sites More sharing options...
Ian C Posted September 27, 2005 Share Posted September 27, 2005 Unfortunately, due to it being a Toyota, I've never had to replace a single bulb in 4.3 years of ownership so I've no idea -Ian Quote Link to comment Share on other sites More sharing options...
Keith C Posted September 27, 2005 Author Share Posted September 27, 2005 Good point - front headlight bulbs. Quote Link to comment Share on other sites More sharing options...
Pete Posted September 27, 2005 Share Posted September 27, 2005 Same as non facelift I think? I swapped mine over from the '94 SZ to my VVTi '97 as they were xenon ones. Straight swap. Quote Link to comment Share on other sites More sharing options...
Jake Posted September 27, 2005 Share Posted September 27, 2005 I've just pulled my ones (98 RZS) to find out. It's got 9005 in the high beam and a different type (bigger lugs) in the dipped. Sadly the dipped bulbs don't have a code number on them. I guess they're either 9006 or 9006J Not much help, sorry Quote Link to comment Share on other sites More sharing options...
Keith C Posted September 28, 2005 Author Share Posted September 28, 2005 Ok, cheers Jake Anyone else able to help? Quote Link to comment Share on other sites More sharing options...
Nic Posted September 28, 2005 Share Posted September 28, 2005 ...in facelift lights? Got some free ones for signing up to Evo, and being the kind, caring husband I am I'm donating them to Faye, so just need to know what bulbs she needs. Ta Keith as said already, they are the same as the J-spec pre-facelift, see details on my post HERE Quote Link to comment Share on other sites More sharing options...
Keith C Posted September 28, 2005 Author Share Posted September 28, 2005 Ok, lets give that a go Quote Link to comment Share on other sites More sharing options...
Keith C Posted September 28, 2005 Author Share Posted September 28, 2005 Apparently it needs to be an H number, eg H1 or something. Quote Link to comment Share on other sites More sharing options...
supRo Posted September 28, 2005 Share Posted September 28, 2005 This is for UK lights but gives the H codes..hope it helps http://www.consumabulbs.com/files/nproduct.php?PHPSESSID=72b66e62ad749975239bd41edf69e439&mk=66&md=879&brn12=&brn24=&x=14&y=9 Quote Link to comment Share on other sites More sharing options...
ivan Posted September 28, 2005 Share Posted September 28, 2005 That's HB3 and HB4 then. Quote Link to comment Share on other sites More sharing options...
Nic Posted September 29, 2005 Share Posted September 29, 2005 That's HB3 and HB4 then. Keith, HB3=9005 & HB4=9006 they are the same just different bulb codes, I think one is a US description. Quote Link to comment Share on other sites More sharing options...
ivan Posted October 2, 2005 Share Posted October 2, 2005 Doesn't one have larger lugs than the other Nic? I thought the 9006 needed trimming slightly to fit in place of 9005's? Quote Link to comment Share on other sites More sharing options...
RedM Posted October 2, 2005 Share Posted October 2, 2005 H3 and H4 are interchangable. Got some from work and fitting them took seconds. Quote Link to comment Share on other sites More sharing options...
Nic Posted October 3, 2005 Share Posted October 3, 2005 Doesn't one have larger lugs than the other Nic? I thought the 9006 needed trimming slightly to fit in place of 9005's? No it's the 9006 that is the problem, if you look at the pics on the link HERE you'll see that the 9006 is the only bulb with a 22mm body diamter, so it will not fit in either the hole for the 9006J or 9005J in the headlights. The 9005 has a 20mm body, so will fit in both holes, but will need slight 'tweaking' to get the connector to fit. Quote Link to comment Share on other sites More sharing options...
Steve W Posted October 3, 2005 Share Posted October 3, 2005 H3 is the thin FOG light bulb. H4 is the older Twin-Filament bulb (Escort/Sierra etc etc) HB3 is the 9005 HB4 is the 9006 (or is it the other way round ) I've just bought some more 'Blue/white' bulbs and am gonna try 'em tonight/tomorrow and will report back on results (possibly wiv some 'anorak's piccies ) Bought ALL 9005's, 2 x Philips, 2 x 'cheap' brand. and, 2 x Fogs. and have 2 x 100w/Whites in the Highs at moment. FatS. Quote Link to comment Share on other sites More sharing options...
