Dashboard and speedo cluster warning lights & auto gear select lamp
CarlM
I've got all my dash apart as I'm fitting a new head-unit and restoring the panels
I tried various searches but can't find definitive answers to my questions
Firstly, I've got some lamps not working on the speedo cluster, also I believe the warning triangle lamp (master warning light) is missing
I'd like to replace them all with OEM style lamps, does anyone know where I can get these I could only find information on LED replacements
I'm aware that are they are T5/T10, can I fit direct LED replacements, if so, what are people going for? Ideally I'd just like OEM style lamps
Second question is what warning lights should be present when you turn the ignition on? They all go off when I start the car - Mine is like this
Left:
Airbag OFF
Seatbelt ON
Door (Only when door is open)
Battery ON
Catalyst ON
Rear lights ON
Should my airbag light be ON too?
Right:
ABS (Comes on then goes off)
Engine Warning OFF
Oil Level ON
Oil Pressure ON
Should I have anymore warning lights displayed on the right hand side? Does your ABS light come on then go off?
Speedo cluster:
Slip Cont ON
Slip Cont Off ON
Brake System Warning Light ON
Is this the same for everyone?
Thirdly, how to do I change the lamp that lights up the PRND2L next to the auto lever, and what lamp is required?
Cheers
Carl
Edited by CarlM (see edit history)
