coza Posted August 1, 2017 Share Posted August 1, 2017 Hi the car will be single turbo 6speed import I'm not sure which ecu to use I've currently got an emu ready to fit are these good ? Is anyone else running that's I've heard the link ecus are good now in stuck on what to put on Quote Link to comment Share on other sites More sharing options...
Tyson Posted August 1, 2017 Share Posted August 1, 2017 Hi the car will be single turbo 6speed import I'm not sure which ecu to use I've currently got an emu ready to fit are these good ? Is anyone else running that's I've heard the link ecus are good now in stuck on what to put on Best to specify a budget otherwise everyone will just say Syvecs. Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted August 1, 2017 Share Posted August 1, 2017 yep as above Quote Link to comment Share on other sites More sharing options...
coza Posted August 1, 2017 Author Share Posted August 1, 2017 Best to specify a budget otherwise everyone will just say Syvecs. Around £1000-1500 Quote Link to comment Share on other sites More sharing options...
Axl Posted August 1, 2017 Share Posted August 1, 2017 Best to specify a budget otherwise everyone will just say Syvecs. Syvecs Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted August 1, 2017 Share Posted August 1, 2017 (edited) Around £1000-1500 Is that overall budget i.e ECU, sensors et cetera or just for the ECU? New Maybe? Megasquirt MS3Pro Ultimate Emerald K6 ECU New Link G4 is within budget AEM Series II (you might be able to pick up from a dealer if they will sort out a price) Secondhand MoTeC M800 Syvecs S6 Ideally you want to choose your mapper first and chat through with them what ECU's they are happy mapping on. Edited August 1, 2017 by Frank Bullitt Spelling. (see edit history) Quote Link to comment Share on other sites More sharing options...
Hitbox Junkie Posted August 1, 2017 Share Posted August 1, 2017 syvecs Quote Link to comment Share on other sites More sharing options...
Style Posted August 1, 2017 Share Posted August 1, 2017 For that budget I'd say Link or maybe AEM. Best ask your mapper what he can actually work with first Might get lucky and get a second hand Syvecs around that figure Quote Link to comment Share on other sites More sharing options...
chazuk Posted August 1, 2017 Share Posted August 1, 2017 (edited) My old power fc daniel has got for sale in parts think it's £500, plug and play ecu and uses factory sensors knock ,oil pressure etc ,Syvecs struggled to make any more power to be honest had to run more boost. With the saved money get a £270 Aem failsafe gauge you can set boost and afr levels in a really nice pc app software that connects up to the gauge also does datalogging, you can set alarms and also has an output line so you can wire it up to boost controller, ignition cut etc and set the time http://aemelectronics.com/files/instructions/30-4900%20Wideband%20Failsafe%20Gauge.pdf Edited August 1, 2017 by chazuk (see edit history) Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted August 1, 2017 Share Posted August 1, 2017 If you have a TT loom, then get a Link plug and play G4+ SupraLink. That will run all the stock sensors, you just need to wire in a boost controller and off you go. Quote Link to comment Share on other sites More sharing options...
coza Posted August 1, 2017 Author Share Posted August 1, 2017 I was thinking a link but I've already got the emu with all loom ready to go on , I just don't know if it's any good and the differences between link and emu Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted August 1, 2017 Share Posted August 1, 2017 (edited) Don't fit the EMU to a single turbo Supra, do it properly and reliably with a standalone. E2A I'm not saying it can't be done (Ian C's Supra is a prime example that it can). I don't think many people map Supra's using these anymore especially when the is much better out there, sell it and put the money with the £1500 you have and get a nice standalone with all the safety features, traction control et cetera you could wish for. Edited August 1, 2017 by Frank Bullitt (see edit history) Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted August 1, 2017 Share Posted August 1, 2017 I was thinking a link but I've already got the emu with all loom ready to go on , I just don't know if it's any good and the differences between link and emu If you have the latest EMU Black, then stick with that. It is pretty nice in terms of features, quite competitive. But if it's one of the older ones then I wouldn't bother Quote Link to comment Share on other sites More sharing options...
sebas Posted August 1, 2017 Share Posted August 1, 2017 Don't fit the EMU to a single turbo Supra, do it properly and reliably with a standalone. why do you think that emu is not good for single supra? Or maybe you thing about old GReddy e-manage Ultimate? EcuMaster Emu is a standalone engine managment unit. http://www.ecumaster.com/products/emu-black/ Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted August 1, 2017 Share Posted August 1, 2017 maybe you thing about old GReddy e-manage Ultimate? That is exactly what I was thinking you meant Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted August 1, 2017 Share Posted August 1, 2017 If you have the latest EMU Black, then stick with that. It is pretty nice in terms of features, quite competitive. But if it's one of the older ones then I wouldn't bother Didn't a club trader melt a forum members engine because of a bad EMU ecu (not emanage ultimate) Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted August 1, 2017 Share Posted August 1, 2017 Didn't a club trader melt a forum members engine because of a bad EMU ecu (not emanage ultimate) I thought it was an ex-trader on here? Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted August 1, 2017 Share Posted August 1, 2017 Didn't a club trader melt a forum members engine because of a bad EMU ecu (not emanage ultimate) From the thread it read that the engine was detonating, so maybe tune related. Quote Link to comment Share on other sites More sharing options...
Krister Posted August 2, 2017 Share Posted August 2, 2017 Ideally you want to choose your mapper first and chat through with them what ECU's they are happy mapping on. ^ This Your ECU is just as good as your mapper is. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted August 2, 2017 Share Posted August 2, 2017 ECU Master black edition should be in Budget I dont think Greg in ProTuner is not too far from you , he does a range of brands , be worth asking what he recommends Quote Link to comment Share on other sites More sharing options...
coza Posted August 2, 2017 Author Share Posted August 2, 2017 I've got the emu silver one - the mapper is happy to use it and he said it will work , he did mention about syvecs so is no one using this on there builds? Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted August 2, 2017 Share Posted August 2, 2017 People tend to stick with what the majority run and the majority on here run Syvecs. It is a great ECU that includes everything in the price, the only other one I would consider would be a MoTeC. Their support is unparalleled and they are mucho £££ but then the best usually is. Who are you getting to map the car? Quote Link to comment Share on other sites More sharing options...
berg Posted August 2, 2017 Share Posted August 2, 2017 ECU Master black edition should be in Budget I dont think Greg in ProTuner is not too far from you , he does a range of brands , be worth asking what he recommends He will recommend Link as he did to me, saved myself alot of £££ over the syvecs and its a superb bit of kit, i hadnt even read about the new plug in G4+ until he recommended it You will get the ecu, all sensors and even a Toucan for less than just a Syvecs on its own Each to their own though Quote Link to comment Share on other sites More sharing options...
and1c Posted August 2, 2017 Share Posted August 2, 2017 Looks a decent ECU though I am not familiar with it. If the tuner is happy to tune it then why not? It will do the job nicely. Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted August 2, 2017 Share Posted August 2, 2017 (edited) It seems a few are now venturing into the Link G4+ which is great as it opens up more avenues for others rather than just the usual one or two, how does their support and features compare? E2A Is this (http://dealers.linkecu.com/TS2JZPlus) the one you went for berg? Edited August 2, 2017 by Frank Bullitt (see edit history) Quote Link to comment Share on other sites More sharing options...
