Items Needed For NA to TT Conversion
Notts_TT
http://www.mkivsupra.net/vbb/showthread.php?136136-NA-to-TT-engine-transplant-step-by-step-guide-(Pic-heavy) this may be a useful thread for you.
Parts...
-Complete TT engine (with loom)
-TT Dial cluster
-TT airbox
-TT Inlet pipe (goes from the airbox to the manifold0
-TT throttle cable
-TT power steering reservoir
-Intercooler and piping
-Uprated clutch/tt autobox
-TT igniter pack
-TT ECU
-TT throttle control ECU
You need a miracle in so far as you need to find a 20 plus year old engine and loom that doesn't need substantial work whilst out of the car and accessible. Things like new valve stem seals, ALL new core plugs, possibly a new oil pump, definitely a new water pump, cam belt, cam belt tensioner and crank damper, injectors cleaning and flow testing, new coil packs would be nice, blah blah. All infinitely easier done BEFORE you drop the engine in the shell....
