evinX Posted July 28, 2017 Share Posted July 28, 2017 So at one point i will like to tackle my fuel lines for the car. Now to do the job with OEM Toyota parts you have to drop the subframe to fit them which seems like a pain. I would like to rebuild the hardlines as you would for brake lines with some non rust Kunifer pipe and a pipe bender and flaring tool. But with the OE rubber fuel hoses id like to have them made up in braided line with all the correct fittings on them, Male/ Female/ Banjos. Heres a diagram i have been working on, not being familiar with the setup it took me ages to figure out what goes where exactly. Right now id like to find out about the diameter of the pipe work to use, Where and who can make the braided lines for me. This is all about making the car future proof as OEM Toyota steel lines dont last. Ill update as i progress with this, for the time i thought id share, and any input from you all would be great. Kev Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 29, 2017 Share Posted July 29, 2017 Why not do the lot in braided Teflon lined hose? Simpler and cheaper. Speedflow will make the hose and fittings up. Dunno if they will flare hard line. Quote Link to comment Share on other sites More sharing options...
