AVC-R question
HedgehogSandwich adi
The AVCR has a boost display on it (digits) and will measure a MAP (manifold absolute pressure) sensor attached to the INLET Manifold. (Actually in the throttle body.)
You do not control the turbo boost pressure by sensing the individual turbo boost pressure, you contol the pressure actually entering the engine through the inlet manifold.
you don't need anything else really.
If you do then one single gauge is all you need and only then if you want to look at a nice needle dial and not a digital version.
If you're keen and want to know what happening to both turbos and how much boost you drop say across the intercooler then yep fit a gauge to each turbo. But this is well O.T.T.
Pete
Not sure which part of the post you are referring to but...
>If you're keen and want to know what happening to both turbos and >how much boost you drop say across the intercooler then yep fit a
I mean fit a sensor to the turbo manifolds and attach a gauge to the sensor obvioulsy!
I think that was clear but I mean the AVCR has a digital boost gauge and must be fed from a sensor. The sensor normally comes with the AVCR as a package.
Regards
Pete
Sorry, Pete, that was aimed at the first post - I didn't know if he meant he would need sensors in those areas connected to the AVCr or if he needs gauges to read off the values and thereby calibrate the AVCr.
But anyway, the AVCr comes with all the sensors it needs and displays the values, so it can be set up from there without additional gauges.
-Ian
