mike33 Posted July 23, 2017 Share Posted July 23, 2017 Hi guys quick question! I have got a set of led rear lights never had a issue on two supras! I have fitted them to a gz supra old lights work fine connected up my led lights and brake lights work fine but indicators are dim reverse lights dim and when hazards are on reverse lights and indicators flash! This is when ignition is just on engine not running! When engine is running rear lights behave correctly no issues! I'm a bit stumped! Has anybody has this problem at all! Link to comment Share on other sites More sharing options...
SupraLEDrears Posted July 23, 2017 Share Posted July 23, 2017 Try changing the indicator relay and check the loom itself Link to comment Share on other sites More sharing options...
ibby Posted July 24, 2017 Share Posted July 24, 2017 Check you're earth's. On the original wiring loom Link to comment Share on other sites More sharing options...
mike33 Posted July 24, 2017 Author Share Posted July 24, 2017 Cheers guys will check this! Just really strange as the pre facelift lighys that came with the car are fine! Link to comment Share on other sites More sharing options...
SupraLEDrears Posted July 24, 2017 Share Posted July 24, 2017 Cheers guys will check this! Just really strange as the pre facelift lighys that came with the car are fine! OEM Lights have bulbs, the LED's pull a lot less current. Link to comment Share on other sites More sharing options...
