The Raven Posted November 6, 2020 Author Share Posted November 6, 2020 So i have plans over the next few days, my headlights are now letting so much water in the look like fish bowls. So i will remove clean and reseal. Also TCB can supply aero seals for 200 quid having never changed them i will do that. I have new window trims to do I want to adjust the passenger window up slighly And then an MOT at the end of the month. Link to comment Share on other sites More sharing options...
The Raven Posted November 6, 2020 Author Share Posted November 6, 2020 (edited) Double posted.. So will keep this for updates Edited November 6, 2020 by The Raven (see edit history) Link to comment Share on other sites More sharing options...
Annabella Posted November 6, 2020 Share Posted November 6, 2020 Car looks really good, nice alloys. Link to comment Share on other sites More sharing options...
The Raven Posted November 7, 2020 Author Share Posted November 7, 2020 (edited) So today I decided to fit the widow trims and adjust the windows. Also fitted the cup holder. First up the easy bit cupholder Next the before window trim I took off the door panel and the reason for the window being off was all to clear the adjuster was set to the bottom. Pulled it up and tightened. Next remove old trim again the reason became very clear when I found this I also adjusted the window tilt to fit a bit tighter and fitted the new trims Went for a drive and all is good. However this happened. So she’s parked up until my new rubber cones tomorrow. Edited November 7, 2020 by The Raven (see edit history) Link to comment Share on other sites More sharing options...
mwilkinson Posted November 8, 2020 Share Posted November 8, 2020 Has that part of the window trim broken off, or has it torn and folded back on itself with the movement of the window? Link to comment Share on other sites More sharing options...
The Raven Posted November 8, 2020 Author Share Posted November 8, 2020 (edited) 1 hour ago, mwilkinson said: Has that part of the window trim broken off, or has it torn and folded back on itself with the movement of the window? It had been broken off. The other side was the same to. My guess is it wasn't taken off correctly during paint. As the screw holding it on was painted the same as the car. Meaning when it was removed it was already broken. Edited November 8, 2020 by The Raven (see edit history) Link to comment Share on other sites More sharing options...
The Raven Posted November 8, 2020 Author Share Posted November 8, 2020 (edited) Today I went after the fish bowl head lights. No oven needed they more or less came away by hand after undoing the clips. Tiger seal later and they can be left to dry over night before re install Edited November 8, 2020 by The Raven (see edit history) Link to comment Share on other sites More sharing options...
The Raven Posted November 9, 2020 Author Share Posted November 9, 2020 All back in now to see what happens when it rains Link to comment Share on other sites More sharing options...
The Raven Posted November 14, 2020 Author Share Posted November 14, 2020 MOT failed, main beam headlight on bulb, headlight bulb not level. And the idiot put it though as a Mk3 and failed it for no cats. I have fixed the actual fail problems. And rebooked with an MOT center that knows what they are looking at. Link to comment Share on other sites More sharing options...
mwilkinson Posted November 14, 2020 Share Posted November 14, 2020 Fingers crossed for the re-test. Link to comment Share on other sites More sharing options...
The Raven Posted November 14, 2020 Author Share Posted November 14, 2020 8 hours ago, mwilkinson said: Fingers crossed for the re-test. I’ve already rang them and explained. The vin on my car shows a n/a which isn’t on the annex. Being before 1995 that means it gets a non cat test. Plus they passed it last year. Should be fine Link to comment Share on other sites More sharing options...
The Raven Posted November 17, 2020 Author Share Posted November 17, 2020 And she’s passed. Only note was some slight cracking in the rubber on the ns tyre. Link to comment Share on other sites More sharing options...
HarleyFDMD Posted November 17, 2020 Share Posted November 17, 2020 What a journey! Cars looking awesome now though. Love the colour! 1 Link to comment Share on other sites More sharing options...
The Raven Posted November 22, 2020 Author Share Posted November 22, 2020 So today’s mission was to replace the 3 pin resistor that runs the indicators. Due to fitting leds in the front side and front housings they where running way to fast. Screw that job.... the only way to access it was to get upside down in drivers side wedge a torch and attempt to get my had half way up the dash. The offending item is right at the very tip top of the footwell fuse box. A good hour later I now have normal flashing indicators Link to comment Share on other sites More sharing options...
The Raven Posted December 2, 2020 Author Share Posted December 2, 2020 Tcb package arrived with my new aero seals. will probably wait for better weather before attempting these 1 Link to comment Share on other sites More sharing options...
evinX Posted December 2, 2020 Share Posted December 2, 2020 1 hour ago, The Raven said: Tcb package arrived with my new aero seals. will probably wait for better weather before attempting these Could you do some detailed pics when fitting? Link to comment Share on other sites More sharing options...
The Raven Posted December 2, 2020 Author Share Posted December 2, 2020 1 hour ago, evinX said: Could you do some detailed pics when fitting? Yeah sure. I will do an extended write up. 1 Link to comment Share on other sites More sharing options...
The Raven Posted January 23, 2021 Author Share Posted January 23, 2021 (edited) So decided to take her out from her winter slumber today just get her nice and hot, poodle round and come home. Under the frost i found this. Nice new windscreen incoming. I will see if they will back off when its out so i can seal the offending foam showing at the front of the dash. Edited January 23, 2021 by The Raven (see edit history) 1 Link to comment Share on other sites More sharing options...
The Raven Posted January 30, 2021 Author Share Posted January 30, 2021 All done. Looking how faded the sun screen was I suspect that it was the original screen. Link to comment Share on other sites More sharing options...
The Raven Posted February 28, 2021 Author Share Posted February 28, 2021 (edited) Got my skuttle dipped. Not been out since the snow it seems my roof bolts are working a little loose while driving. So on Monday I will order some new ones and change them out with the aero seals when it gets warmer Edited February 28, 2021 by The Raven (see edit history) 2 Link to comment Share on other sites More sharing options...
mwilkinson Posted February 28, 2021 Share Posted February 28, 2021 Nice job Russ. Was that lacquered too? At least this way your cabin ventilation will still work. I've noticed that the genuine carbon ones people are installing don't have the any louvres for the cabin ventilation system Am I missing something? Link to comment Share on other sites More sharing options...
The Raven Posted February 28, 2021 Author Share Posted February 28, 2021 4 hours ago, mwilkinson said: Nice job Russ. Was that lacquered too? At least this way your cabin ventilation will still work. I've noticed that the genuine carbon ones people are installing don't have the any louvres for the cabin ventilation system Am I missing something? Yes mate lacquered up. Link to comment Share on other sites More sharing options...
The Raven Posted March 19, 2021 Author Share Posted March 19, 2021 Got a guy working on my new boot install. test fitted everything today and it all works out. 1 Link to comment Share on other sites More sharing options...
The Raven Posted March 31, 2021 Author Share Posted March 31, 2021 All fitted up looks nice and sounds great 1 Link to comment Share on other sites More sharing options...
The Raven Posted April 4, 2021 Author Share Posted April 4, 2021 (edited) I have found a few annoying stone chips that i am going to get sorted. Summer jobs. Replace aero seals. Mod or replace the roofs parking lock as its rounded off. Replace the front 2 aero roof screws. Replace seat motor. Attempt to regas AC And try and find out why my mirrors dont work. (I know this is to do with my dash loom swap........so im thinking i missed a connector) i have no idea where they are and to be honest im not going to take the dash out again to find it seeing as only i drive the car i have them where i want them. DONE 11/04/21....it had no fuse... Refurb the ignition barrel and re install so i can go back to having one key. Edited April 11, 2021 by The Raven (see edit history) Link to comment Share on other sites More sharing options...
