TT with W58 trans
Izzy
Hi all.
I'm changing auto trans with W58 trans. I have all the parts including NA driveshaft. As I know, the NA driveshaft have different size flange than TT diff have (little bigger than NA). I'm asking what rubber flex-coupler should I use (is any alternative?) or I must get it made?
I know that the W58 trans isn't strong but I got it very cheap. And I have standard TT (no mods) and I drive very conservative ;)
Later I'll change it for something stronger :)
Thanks for the answer :)
You can make it fit, its difficult and fiddly but it can be done and is exactly how i have mine
Im currently using the rear half of an n/a prop on my R154 and its currently mated to a a02b auto TT diff, using the TT rubber
