Ls400 calliper clearance
azam
As in, are they smaller?
I haven't seen them in the metal, but I believe they are smaller than UKs.
Yep as in smaller, the uk spec were touching the wheel face. Well skimming it very lightly. And I don't really want to go about using wheel spacers. Was going to order k sports which I am 99% sure offer more clearance but the ls400 callipers are a lot cheaper.
Spunkmeyer has LS400 calipers and isn't that far from you. ALWAYS try a wheel on a car with the brakes you want to run, and vice versa, unless you have proper accurate measurements, and that sort of stuff is very hard to measure accurately as it's all 3D measurements.
Thanks Chris, I have his old car so I'm sure he won't mind. I will try and have a go at that. And if that fails I can always take the calliper into work and put it on the cmm in metrology to take measurements but again it's time.
