Mike2JZ Posted July 17, 2017 Share Posted July 17, 2017 After sticking my car back together recently I have no power steering. The pump is good, fluid is fresh, no leaks. I went standalone so had to run new wires for the PPS solenoid on the rack back to the interior passengerside orange plug (PPS+ & PPS-) which connects to the powersteering ECU. PS ECU is still reciving speed input from the odometer/speedo circuit and is still getting power from ECU IG fuse. PPS plug by the solenoid is getting voltage and ground. Figured I had a wiring issue which was causing the solenoid not to activate. Tried switch polarity on PPS wires and still nothing. Thought I'd bypass the PS ECU conpletely and give the solenoid direct 12v and still nothing. Anyone had any experience with PPS solenoids dying, or am I missing something? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 18, 2017 Share Posted July 18, 2017 Whatever you do electronically to the PAS "effort" solenoid you should still have power assist. Have you had the pump apart? Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted July 18, 2017 Author Share Posted July 18, 2017 Whatever you do electronically to the PAS "effort" solenoid you should still have power assist. Have you had the pump apart? No, pump has just been swapped from my last setup onto new engine. Was working perfectly before. Fluid is good, no air leaks, no bubbles etc. I've had this exact thing happen before when putting a standalone on another supra, but once the PPS circuit was reconnected the PS system kicked back in. Without that solenoid active, the stiffness locks itself into it's hardest setting. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 18, 2017 Share Posted July 18, 2017 Oh yes, for sure, without any power to the solenoid it will act as if it's doing over X MPH and have less assistance, but there will be some assistance still there, more than enough for effortless parking and manoeuvring for example. I was assuming there was no PAS assistance at all! Quote Link to comment Share on other sites More sharing options...
