just crashed supe!
wkdtime
was on my way home from central London on sunday night, some car racing past clipped my driver side rear and drove off, did not get the number plate! :swear:
Anyways have a look at the damage guys, and let me know what am i looking at i.e, do i need a new pannel? can it be sorted? how about the door? baring in mind the car is going for a respray and having side skirts put on to.
How much are the rear quater pannels?
the door alignment is fine i think, its the rear pannel that has been pushed in, no creases though. which is why it lloks as thought the door is out of alignment.
The rear quarter panels are welded on AFAIK, so much bigger job to replace them. You can get access to the inside of the rear quarter panels by removing the rear speaker mount and trim, so majority of the bump may be able to be knocked out from behind. Mine is much worse than yours at the moment, after some $^%*er hit me whist I was parked, then drove off, been told mine shouldn't be too difficult to fix.
cheers, greenpeace
Speak to Gerald at GVN...would of suggested Dude too but he aint back from Holiday just yet!
But GVN have done a lot of work on Supras, they are great with body panels and I'm sure will charge simpethetically given the circumstances..
Def worth a try! :innocent:
0208-994-1111
Sorry to read/see the damage, but as mentioned earlier, it's not too bad.
If you're after another cover for the vent, email Chase on here,
as I sold both sides vents to him and I know he only needs one.
Not sure which side he used though.
He could post it down to you, they're only plastic so shouldn't
cost a fortune.
Good luck.
Gaz :whip:
