Sparkies - What a difference!
Dragonball
Visited Nito and fitted the newies via Alex (thanks Guys)
Nice and easy job for those about to attempt - just make sure you have long reach attachment to get to the sparks (technical term please guys?)
Took about an hour
What a difference in boost - that loss of power seems to have gone and car idling much happier
Generally better feeling all round!
Highly recommended for those suffering that 'hesitation' at higher speeds!
Cheers
Paul
:thumbs:
Originally posted by Keith C
What's the NGK's of choice these days? I reckon I need to run a grade colder than stock.
Keith
if you've not changed those plugs since you got the car, as far as i know they're the original from-new factory-fitted platinum-tipped plugs. I certainly didn't change them and i don't think either of the previous 2 owners did either.
They were scheduled to be changed at the last service before i sold it to you, but the plug-change was the one item i politely declined as it was £100 + and i wasn't getting any misfires or rough running, so i figured i'd save 100 notes.
but they could probably do with being changed now, i agree.
think recommended interval for platinum plugs is 60k miles.
cheers
IK22's or 24's are £65 delivered. They are coldness 7 and 8 respectively. Stock are grade 6.
The NGK BKR7E's are Grade 7 and also work for a much lower cost, but you have to buy them more often and they don't come pre-gapped for high boost.
I had spluttery problems at high boost. Then I got some NGK PFR7B 4853 laser platinum plugs and everything was sweet there after. Got em off Chris Wilson.
I copied (:p ) Justin - after re-checking with Chris....
Stopped all my Hesitation under high load/boost.
They are actually listed for the Nissan Sunny GTiR and so are
'fairly' readily available.... AND NOT TOO DEAR EITHER ! !
[ they are, in reality a 1-step-colder plug in Platinum, BUT, unlike
the originals (which are pre-gapped at 1.1mm) the PFR7B's are
pre-gapped ~0.8mm = IDEAL for high boost / de-cat ! ]
Only problem I had was that because they are for the Nissan, both
my local suppliers had FOUR each :music: so had to have 4 + 2 !
