SUPRA4EVA Posted July 12, 2017 Share Posted July 12, 2017 Noticed my pads are wearing thin and my discs MAY need replacing too. Been looking at OEM stuff but found BLUE PRINT discs and pads a lot cheaper. No crazy sh*t, just for regular road use. I just wanted confirmation that these will fit a UK Spec, numbers SEEM to check out. Front brake pad ADT34251 (only the 1 type, OEM has 2...) Rear brake pad ADT34250 Front brake disc ADT343158 Rear brake disc ADT343111 Anyone know if there is an aftermarket kit for the clips and/or shims? I found a quality Delphi kit for my MR2 in the past... Link to comment Share on other sites More sharing options...
Chris Bailey Posted July 12, 2017 Share Posted July 12, 2017 Don't do it! A good friend of mine crashed his supra due to Blueprint UK spec discs which overheated and didn't stop the car. Don't cut corners on brakes, it's just not worth the risk! Link to comment Share on other sites More sharing options...
Al Massey Posted July 12, 2017 Share Posted July 12, 2017 I wouldn't do it Pads, id always go Chris Wilson. Disks, well any good brand really Link to comment Share on other sites More sharing options...
blythmrk Posted July 12, 2017 Share Posted July 12, 2017 Check the stock of the rears as they were discontinued! The rears were oem ones in blue print boxes when I bought them 12 years ago! The front blue print ones are not sided like the oem discs I think the cooling fins are directional on the oem ones? It all depends on how hard you are going to drive eg normal road use or fast road/track? Link to comment Share on other sites More sharing options...
drift_bear Posted July 12, 2017 Share Posted July 12, 2017 As mentioned DO NOT touch these discs! I'm sure the member will be along shortly.. Link to comment Share on other sites More sharing options...
SUPRA4EVA Posted July 12, 2017 Author Share Posted July 12, 2017 I understand OEM is superior but are they really that bad? Even for a stock car, normal road use? I read BLUE PRINT are a decent brand and the pads at least, are stamped made in Japan. Link to comment Share on other sites More sharing options...
Grasmt Posted July 12, 2017 Share Posted July 12, 2017 That should say it all Link to comment Share on other sites More sharing options...
Benjy Posted July 12, 2017 Share Posted July 12, 2017 Blue Print discs are made of cheese. ONLY use OEM discs with a good pad, such as Chris Wilsons. Even OEM pads! Link to comment Share on other sites More sharing options...
SUPRA4EVA Posted July 12, 2017 Author Share Posted July 12, 2017 Well, I guess the picture does say it all. I'll just have to get OEM as I do care about my Supra. Good looking out. It's just that I've never got parts for a Supra before and it's NOT easy these days finding them, not just brakes and pads. It's pretty much looking at the online catalog to make sure the part is correct and then off making quotes to see who can offer the best price...and I keep giving up lol Who would you recommend for competitive OEM prices and good to deal with? Link to comment Share on other sites More sharing options...
Benjy Posted July 12, 2017 Share Posted July 12, 2017 TCB Parts. 01579 383879 Link to comment Share on other sites More sharing options...
Scooter Posted July 12, 2017 Share Posted July 12, 2017 Or amayama for small light parts. Link to comment Share on other sites More sharing options...
ripped_fear Posted July 12, 2017 Share Posted July 12, 2017 I echo the above infact I have a set of nearly new front UK disks you can have mate one has slightly warped so needs skimming but the other is fine. They are genuine most importantly too. Blue print stuff is crap I only.once used them on my old supra and within a month I was swapping them out as they were noticeably worse than my worn oem ones I had removed. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted July 13, 2017 Share Posted July 13, 2017 I have used Bluprint and other third party parts for years, on lots of different cars without any issues whatsoever, by the appearance of the disc i would be inclined to say that the overheat issue was down to pads binding causing the discs to overheat long before the brakes where applied in earnest, and subsequent crash. Most brakes rotors and pads apart from carbon will end up loosing braking power once certain temps are exceeded, the same could have happened with any make including OEM. Link to comment Share on other sites More sharing options...
bignum Posted July 13, 2017 Share Posted July 13, 2017 https://uploads.tapatalk-cdn.com/20170712/7da4be94c2a4a57a149c296c961b80c2.jpg That should say it all /QUOTE] Wow they really are blue, yikes. Link to comment Share on other sites More sharing options...
clay Posted July 13, 2017 Share Posted July 13, 2017 tcb parts. 01579 383879 what he said try... Tcb Link to comment Share on other sites More sharing options...
Benjy Posted July 13, 2017 Share Posted July 13, 2017 I have used Bluprint and other third party parts for years, on lots of different cars without any issues whatsoever, by the appearance of the disc i would be inclined to say that the overheat issue was down to pads binding causing the discs to overheat long before the brakes where applied in earnest, and subsequent crash. Most brakes rotors and pads apart from carbon will end up loosing braking power once certain temps are exceeded, the same could have happened with any make including OEM. The only part that wasn't OEM or uprated were the front discs. The calipers weren't binding. In 4 years, an identical set up except OEM discs have never caused an issue. 3 months these had been fitted, and they cooked after 3 roundabouts, 2 of which weren't particularly hard stops. I have spoken to Blueprint. They're no longer considered "OEM Equivalent", because they claimed them to be "99% equivalent" in an e-mail to me, which my solicitor was all over like a rash. Link to comment Share on other sites More sharing options...
Iky Posted July 13, 2017 Share Posted July 13, 2017 Don't really like Blueprint discs. Seen them on Celica's and they never fit properly, the centre bell catches the backing plate. Link to comment Share on other sites More sharing options...
