Nic Posted September 26, 2005 Share Posted September 26, 2005 Since getting my new computer I still can't get the CD setup to work I need the diagram showing the speedo/rev counter unit please, if someone would be so kind Quote Link to comment Share on other sites More sharing options...
Homer Posted September 26, 2005 Share Posted September 26, 2005 Is this the bit? Quote Link to comment Share on other sites More sharing options...
Nic Posted September 26, 2005 Author Share Posted September 26, 2005 Is this the bit? Cheers D that's the little monkey Now all I need is someone to explain how to get around the disc space error messafe when trying to do CD setup in XP Quote Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted September 26, 2005 Share Posted September 26, 2005 You have to fill your hard drive up with crap until you have less than 2Gb of space, then it allows you to install it all, I have mine running off of CD as I didn't do it correctly and I can't be bothered to sit around and fill up 100Gb to get back to less than 2Gb. I have the instructions somewhere in a small file if you want me to email it to you? Quote Link to comment Share on other sites More sharing options...
Nic Posted September 26, 2005 Author Share Posted September 26, 2005 You have to fill your hard drive up with crap until you have less than 2Gb of space, then it allows you to install it all, I have mine running off of CD as I didn't do it correctly and I can't be bothered to sit around and fill up 100Gb to get back to less than 2Gb. I have the instructions somewhere in a small file if you want me to email it to you? Cheers for the info Ben I can't even set up to run off a CD, which is how I use to do it and what makes it even more complicated is that I'm trying to run it using Vitual PC (windows xp) on a Mac, which use to work, but whatever I do now I can't get it to set up the CD. Can you send the file to nicvollans @ netvigator . com Quote Link to comment Share on other sites More sharing options...
